![]() Join Date: Aug 2008
BBC into 60-66 4x4
My plans are to put the 402ci big block from a 71 C30 donor truck into my 64 4x4 short wheel base pickup. My pickup currently has a 350 backed by a sm465 trans and rockwell t221 transfer case.
I've read the tread about putting a bbc into a 67-72 4x4 pickup and taken a look at the DIY engine crossmember. Although I cannot figure out why they refer to the 67-72 as a "first gen" ![]() From what I know about 1/2 ton pickups the 64-66 and 67-72 front crossmembers are pretty darn similar. So i'm wondering if this will work in my 64 4x4. Maybe its possible to install and modify the stock bbc crossmember and mounts from the 71 into my 64? Has anyone here done this before?
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
Re: BBC into 60-66 4x4
I haven`t done this,but the frames are about the same.How exactly the same,I don`t know for sure.But,I think when they say "1st generation" I believe they are more Blazer oriented as an extreme trail vehicle.They say 69-72 not 67-72 which goes along with what I`m saying.There is no difference between truck and Blazer.So,whatever you see for blazers will go on a truck as well.
Im doing one right now, but i think my frame is a 60-62? (IT HAS A ROUND TUBE FRONT CROSSMEMBER)
We did a couple years ago. I think the firewall has to be "massaged" on the passenger side under the heater.
i seen a 2wd about that year and the pass. valve cover was under the fire wall it was a 454 and drivers side wasn.t far from it i was told it could be moved forward a few inches but looked shady on this one just my .02
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_- 1972 K10 4"lift 33"tires (soon to be bigger and better) 2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's |
