Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-11-2008, 10:50 PM   #1
AlienYouth
AlienYouth's Avatar
Help me hook! :)
well, i got 325 gforce TA's and a locker, my rear is lowered 6", stock shock location
where should i start? i may buy full slicks in spring, but right now, i feel like there's another area that needs improvement since i can do burnouts at highway speed and make less than 500 HP... lol
my thoughts are buying 3" drop springs up front (raise the front an inch) and new shocks and relocate the rear shocks. my question is will the shocks be good enough, or should i do coilovers or something different before i buy new shocks and they end up not helping... srry for the long post
here's a pic, since i havent posted one in a while
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 12-11-2008, 11:20 PM   #2
phipp13
THE DAMN YANKEE
phipp13's Avatar
Re: Help me hook! :)
St Marys County MD here. 1st do you have trailing arms or leaf springs?? cal tracks for leafs. what it sounds like to me is when you lowered your truck sooo much you may have lost your negitive pinion angle. your angle should be 2 to 3 degrees neg.. if you have no neg pinion you have no traction. i'm no pro with these trucks but thats where i'd start at. pm me if you have more questions. DJ is really knowledgable as well as quite a few others on this site phipp
phipp13 is offline   Reply With Quote
Old 12-12-2008, 08:58 AM   #3
Lx3
Lx3's Avatar
See if you can get your hands on a book called Auto Math by John Lawler.
If you're a do it yourself type guy. If not find a Pro. It can look like
"Black Magic" but it's really just matching and tuning. Right tune and
parts will "dead hook" but mismatch or skimp and things start breaking.
Good Luck.
Lx3 is offline   Reply With Quote
Old 12-12-2008, 01:10 PM   #4
Super73
Super73's Avatar
Can you explain "spinning the tires at highway speeds.." On a shift or down shift? Rolling in to the throttle?
I'm assuming your truck is a trailing arm set up?
Auto or 4 speed? If auto, what size converter?
Any idea of your weight bias and total weight?
My 01 SS had pretty good suspension but shifting 1-2 or even 2-3 with the manual, it had no problem breaking them loose with even a 275/40/17 drag radial with the factory 3.42's. That was at 335rwhp and it was worse when it made 405rwhp. When I went to a 4.10 and a 28x11.50 ET street, even after a decently big burn out, it would still leave 20ft strappers on the 1-2 and 2-3 shifts on the street.
My truck makes more power than my car did. It's a little more dificult getting it out of the hole on the street with the big conveter, but it dead hooks the shifts.
The point I gues I'm trying to make here, is depending on how your driving a manual, it is going to shock the tires harder on the shifts.
If you can give us a little more info, we'll be able to give you better advice.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 12-12-2008, 09:00 PM   #5
Lx3
Lx3's Avatar
The info needed to calculate can be pretty detailed. And I would need
alot of info. Try to find the book I mentioned and I'll see if I can find
something online to help. But all the power in the world is useless if
you can't put it to the ground and spinning the tires at highway speed
is flat dangerous. I'll get back to you.
Old 12-13-2008, 01:11 AM   #6
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
If you have the coil spring rear end you don't need to do much.
I recommend a Rancho Rs 9000 in the rear w/ relocators.
and a good 3 way for the front. or a single stage lake wood.
Start at 5 then work your way up and down till you get some reaction. Air pressure is also important. Play w/ it. it can improve your 60'.
I run a '68 that run 12's w/ a 1.64 60'. Rs 9000 on all 4 corners. Hoosiers 26x10's for race and 28x13.5 m/t DOT for street.
68 C-10 KID is offline   Reply With Quote
Old 12-13-2008, 02:06 AM   #7
LuckyHenriksen
LuckyHenriksen's Avatar
Truck looks good, what backspace is on your wheels?
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-13-2008, 02:23 AM   #8
68 C-10 KID
Mean Green
I run a 6" for race and a 4 1/2 for street. But i have extended my wheels tubs 6"
Old 12-13-2008, 08:55 AM   #9
AlienYouth
AlienYouth's Avatar
Thanks for all the suggestions, it is trailing arm, TH400 w/ 3000 stall
i'm sure the weight bias is terrible, and total weight is probably at least 4600 with me, but i'm makin a trip to the dump today, so i'll let ya know
these are the rear wheels... 3.75 BS
http://store.summitracing.com/partde...5&autoview=sku
i think the wheel/tire combo is perfect with a 6" drop, 325/50s, got an inch of clearance and stick out maybe a half inch
i think ima go ahead and do shocks and relocate, since anything i do is gonna start there...
i'll look for that book, maybe make my own shock brackets to get it just right (and cause i'm cheap)
again, thanks for all the help
Picturesss
71 C10 383/TH400
Old 12-13-2008, 12:45 PM   #10
djracer
djracer's Avatar
any weight you can get off the front or relocate from the front to the rear will be a big help. I would move the battery and fuel to the very rear and lose the tool box.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 12-13-2008, 04:31 PM   #11
Super73
Super73's Avatar
Or put the tool box at the gate and make some room in it for a fuel cell and your batterey I would b interested to see the weight bias change with just moving the toolbox to the rear of the bed.
I'm assuming it's spining on a downshift when you lay in to it?
since you are as low as you are, the rear maybe squating but hitting the bump stops and putting a shock through your rear suspension. Might want to look there first.
Old 12-13-2008, 04:32 PM   #12
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
x2 with what Dj said.....you could hide some turbos in the toolbox(o wait you Wanted to hook em not Cook em, my bad)
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 12-13-2008, 04:34 PM   #13
LuckyHenriksen
Sweet I just got some wheels with the same BS and width, and Im happy to know that I can fit that size of tire in there. Are your inner wheel tubs widened at all? Or are they stock
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-14-2008, 02:06 AM   #14
AlienYouth
AlienYouth's Avatar
thanks for the suggestions, my truck is actually only 4140 with me, my toolbox, and some other junk in it... my truck is gonna be on hold for a couple weeks while i get my new daily driver (datsun 521) roadworthy (old one went up in flames )
relocating the fuel tank is also up there in the list of things to do, just gotta find time to work on all my junk
and joey... i had just started workin on a TT setup when my other junk blew up, but it's still in the future
rear wheel tubs are stock
thanks again
Picturesss
71 C10 383/TH400
Old 12-14-2008, 04:43 PM   #15
scatesracing
Machinist
scatesracing's Avatar
My truck was the same way at one time....... the biggest help for me (was pointed out by one of my circle burner bubbies) was the fact that my pan hard was not even close to being level. I didnt think it would help.... but it did in a big way... less side movment when it squats... like pulling the rug out from under ya.. just my 2 cents
scatesracing is offline   Reply With Quote
Old 12-27-2008, 05:18 PM   #16
redhead69
fugedaboutit
redhead69's Avatar
my truck was like that then I realized I had some overload coils in addition to the regular coils. I took those off and the weight transfer/traction was immediate>
Currently truckless
redhead69 is offline   Reply With Quote
Old 12-27-2008, 06:22 PM   #17
68 C-10 KID
Mean Green
So what panhard bar did you go with?
Old 01-02-2009, 11:21 AM   #18
Tmiller
slims 68
I have 5" drop in mine with adjustable panhard bar stock location. My biggest inprovement was the reinforcment kit on the trailing arms. Deffinately stopped the side to side lunge under tire spin. Friends told me on the strip the whole truck is jumping straight up in the air and unloading the rear, so my plan is to put short coilovers on the front to limit travel and tranfer weight, then long double adjustable coilovers on the back to give plenty of adjustment and travel.
68 c10 LWB, blown 454 , 550 hp & 600 tq est.
06 Chevy Cobalt SS supercharged 2.0L
08 Chevy silverado crew cab 1/2 ton 2wd 5.3L, she wont let me put a supercharger on it.
Tmiller is offline   Reply With Quote
