Old 01-02-2009, 04:29 PM   #1
mbrekke
2wd to 4wd
have any of you guys ever converted a 2wd 1971 c10 to a 4wd
just wondering how much work it involves
mbrekke is offline   Reply With Quote
Old 01-02-2009, 04:37 PM   #2
Wreckless_71
Wreckless_71's Avatar
Re: 2wd to 4wd
This should be moved to the 4x4 forum... I've done or am in the process of doing a full frame body swap...
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 01-02-2009, 04:47 PM   #3
Yukon Jack
Yukon Jack's Avatar
Re: 2wd to 4wd
Yep, head over to the 4x4 subforum - there is almost always an active post asking about this.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-02-2009, 04:55 PM   #4
longhorn_SD69
longhorn_SD69's Avatar
Re: 2wd to 4wd
take what you got now and find a 4x4 frame that it will fit on but i would talk to the 4x4 frame. something else you need to look at is your low hump in the cab you might need to find a high hump floor for it
Good Wood
longhorn_SD69 is offline   Reply With Quote
