Old 01-03-2009, 03:08 AM   #251
Captainfab
60-66 Nut
Re: Our '66 Short Fleet Build
You're making some outstanding progress Joe!
I would just find a sandblaster that doesn't use silica sand and take the cab to him instead of soda. I've heard of some paint issues from blasting with soda.
Old 01-03-2009, 03:16 AM   #252
joe231
joe231's Avatar
Thanks Capt!
what issues have you heard of?
you think I should find one that uses walnut shells or ???
just don't want regular sand to heat up the metal and warp it.
i haven't really researched it much yet....
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-03-2009, 03:35 AM   #253
Captainfab
60-66 Nut
I can't remember details at the moment, but some primers may not react well to any residual soda that may be present, and I'm not sure how well soda really is for removing rust.
My friend that does a lot of blasting for local restoration and hot rod shops uses copper slag......looks like black sand. Nickel slag works well too....it's greenish.
That is definitely an issue, but it is not caused just by the sand. It has everything to do with the operator and his knowledge of blasting automotive sheet metal.
Try checking with some local restoration, and body shops and see who they use/ recommend
Old 01-03-2009, 03:58 AM   #254
joe231
joe231's Avatar
thanks for the info
i will look further into it
I talked to Musclerodz awhile back and he told me of a blasting company around here that uses plastic media, so i will look into it
CHEVY ONLY
Old 01-03-2009, 09:31 AM   #255
TimE
Hey Y'all!!
TimE's Avatar
A fella that I work with sells/restores mopars and parts. He swears by the plastic media blasting.
As Captainfab had stated, if there is any of the soda left in cracks and crevices (and how would you possibly get it all out of the seams??) it can cause you paint heartache later.
On the subject of using sand, someone that is experienced with a sandblaster will not have any issues with metal warpage. The problem is finding a reputable 'blaster in my area.
TimE is offline   Reply With Quote
Old 01-03-2009, 10:16 AM   #256
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Yeap, if you dont know what your doing, sandbasting WILL definately heat-warp the metal...I seen it first hand on my buddys 69 GMC hood.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 01-04-2009, 12:21 AM   #257
joe231
joe231's Avatar
cool, i will be looking into the plastic next week......
not much progress today
moved the engine perches to the forward holes (still need to drill the cross member for the lower bolts) and mounted the 700R4 to the 283 for mock up....found out the motor mounts are SHOT, the rubber has completely separated. I need to go pick up motor mounts and a trans mount before I can build a cross member
i have a set of the newer style motor mounts and perches that i'm debating on using........
disclaimer: the trans is no where near the proper/final position, it is just sitting on blocks to hold it up for now.....
CHEVY ONLY
Old 01-04-2009, 01:22 AM   #258
olsofti
olsofti's Avatar
Lookin' good Joe,I like your fabricated "cab lifter" and it's adjustable.
As far as blasting,I've been using coal slag or Black Beauty fine grit,it will remove rust and paint.It will heat up if you stay in one spot too long,but doesn't pit very much.
I found that for paint removal that a steam cleaner works really well.
olsofti is offline   Reply With Quote
Old 01-04-2009, 01:26 AM   #259
joe231
joe231's Avatar
thanks for the info olsofti!
CHEVY ONLY
Old 01-05-2009, 03:05 PM   #260
MacAttack
283 Drama Queen
MacAttack's Avatar
That cab lifting tooling is outstanding!
Time to start renting it out, or sell plans for us to make it. Looks like it worked slicker than snot! Congratulations on your design and follow-thru.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 01-05-2009, 07:58 PM   #261
kizer
Its Deja Vu time again
kizer's Avatar
Man seeing yours apart kinda annoys me because it makes me feel super lazy for not doing anything.
Thanks for all the cab pictures. Nice to see that gizmo in action
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 01-05-2009, 10:55 PM   #262
joe231
joe231's Avatar
thanks Mac!
feel free to borrow it any time you are around OKC
it was pretty easy to build, the thread link posted back a page or two has all the dimensions on it.
i'll never do the find some buddies/ a-frame/come-a-long thing again
well work is getting in the way of my free time again so it will probably be the weekend before I get anything else done
oh, i did get the cab unloaded at work tonight. the cab jig works well with a forklift also
now I need to get my cab dolly built!
CHEVY ONLY
Old 01-06-2009, 02:48 AM   #263
Sam59
Flat Broke
Man Joe you are one busy guy!!! Keep up the good work, I'll have to come check 'er out one of these days once you get it back together (probably soon from the way you work lol). Let me know if you need a hand, I'm just down the road
Sam59 is offline   Reply With Quote
Old 01-06-2009, 09:01 AM   #264
joe231
joe231's Avatar
thanks Sam!
you, jason65, scotts62, billysbowties, and i will have to get together one weekend
CHEVY ONLY
Old 01-06-2009, 09:13 AM   #265
jason65
Registerd User
jason65's Avatar
thanks Sam!
Yep.
jason65 is offline   Reply With Quote
Old 01-06-2009, 04:43 PM   #266
Sam59
Flat Broke
No doubt, im down
Old 01-06-2009, 06:23 PM   #267
scotts62
One day...
scotts62's Avatar
Yep im in
Scott
93 crew cab build
Project 62
Old 01-09-2009, 05:14 PM   #268
MacAttack
283 Drama Queen
MacAttack's Avatar
Thanks for sharing Joe - that is a serious design.
Old 01-09-2009, 08:19 PM   #269
joe231
joe231's Avatar
CHEVY ONLY
Old 01-09-2009, 08:36 PM   #270
62 short step
62 short step's Avatar
Nice lift Joe! I dont know how I missed this.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 01-09-2009, 08:58 PM   #271
joe231
joe231's Avatar
thanks Jeremy
CHEVY ONLY
Old 01-09-2009, 09:01 PM   #272
protrash64
Resistance is Futile
protrash64's Avatar
Im kinda disappointed, actually. I thought it would have a control panel to show what floor it would go up to.
This is total ..................
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-09-2009, 09:10 PM   #273
joe231
joe231's Avatar
that's a good idea............
CHEVY ONLY
Old 01-09-2009, 11:07 PM   #274
62 short step
1965 c-10
86 chevy c/k 20
Old 01-09-2009, 11:28 PM   #275
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
I agree nice joe......
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
