Never Ending Projects
Re: Pinion Angle Question
Thanks for the info. That's a good site. I actually know how to set a pinion angle but only with the suspension all setup and the car/truck sitting at ride height.
That's my problem, I don't have the suspension installed other then the trailing arms. I went ahead and set the angle and welded the pads on based on my '68 housing. I was able to cycle the axle up and down, connected to the arms and at what "should" be ride height, it looked like the pinion was bout 4* and hitting the bump stops, about 1.4*. It looks like it did with the stock '68 housing so I think I am good but won't know for sure until it's back on the road.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
