Old 01-03-2009, 01:05 AM   #1
greygoose
greygoose's Avatar
Would this work...please help!!!
Would a 68 327 out of a C50 tractor truck,it is the original motor.could it work without having to change out any internal motor parts and would a 350 or 400 th hook up to it.Motor mounts and small stuff I think I can handle,just don't want to get it,if it's gonna be to much trouble ....Need answers please,because I think this might be my diamond in the ruff....
If it ain't a chevy,I don't want it
greygoose is offline   Reply With Quote
Old 01-03-2009, 02:10 AM   #2
sweet70beast
sweet70beast's Avatar
Re: Would this work...please help!!!
Work for what?
Yes a th350 and 400 will bolt up.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 01-03-2009, 07:22 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It's a just a small block Chevy. Underneath that big truck, it's the same thing you're used to. It will go directly into a smaller truck, hook up to the trans, etc...
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-03-2009, 08:22 AM   #4
70GMCer
70GMCer's Avatar
That's what I have always liked about the older Chevy engines. They interchange in just about anything.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-03-2009, 04:45 PM   #5
72armyswbtruck
72armyswbtruck's Avatar
I thought that Chevy also made a larger heavier 327 industrial motor?
Is this true or not?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 01-03-2009, 05:40 PM   #6
john
member #16
john's Avatar
I think that is true. I dont know about the larger part but they were used in harvesters and such. jesse 67 c10 put one in his truck.
http://67-72chevytrucks.com/vboard/s...ad.php?t=12457
john is offline   Reply With Quote
Old 01-03-2009, 08:20 PM   #7
bhoeger70
bhoeger70's Avatar
on some of the heavy trucks the heads were different. they had larger accessory bolt hole and they were in slightly different places. it is an easy modification just drill the bracket holes to a larger size and you need cut and make one bracket longer. Otherwise it will bolt right in but you should change the timing chain and use a four barrel intake manifold.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin
67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts)
bhoeger70 is offline   Reply With Quote
