![]() Join Date: Feb 2005
?? on upper & lower control arms
Does anybody know if the lower control arms will fit later model years like a 1981. As somebody has a set of lowering control arms from a 70 1/2 ton and i have a 81 1/2 ton will they work if i use the later year ball joint.
Designated Grumpy Old Man
![]() Join Date: Oct 2001
Re: ?? on upper & lower control arms
Moving over to the pickup forum where you might get more answers.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
Dave's not here, man
Well, you can use the 81 control arms on a 70 so I see no reason you can't do the opposite. Like you mentioned, the ball joints are different and you would have to put the 81 joints in the 70 arms. Maybe someone that has done this would know for sure, but I am very confident that it will work.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Swap to the correct ball joint and install them. They interchange.
thank you gary
67-72 parts collector,…
![]() Join Date: Nov 2002
Remember the 70 arms will have the steel bushings instead of the rubber bushings like you have in your 81 arms. Other than that,... they will work with a balljoint swap.
