Old 01-06-2009, 01:38 AM   #1
83_383Stroker
83_383Stroker's Avatar
c notch question
okay I am looking at the 3/5 drop kit from Western Chassis and am just curious. Is it absolutely necessary to notch the frame with the 5" flip kit? They sell a 3/5 deluxe kit that includes the c-notch kit for 279.95, or the econo kit for 209.95. Price is not my worry I just need to know if I HAVE to or Highly recommended that i "C" the frame Thanks in advanced!
83' internally ballanced 383 Stroker, 400 turbo 3800 stall , Posi, 750cfm carb, Weind manifold, long tube headers, and a handful of other goodies. Custom billet and woodgrain interior.
83_383Stroker is offline   Reply With Quote
Old 01-06-2009, 01:44 AM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: c notch question
you can go with out a notch and short bump stops, but I would get a c-notch more axle clearance, and it will allow you to go lower
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 01-06-2009, 01:45 AM   #3
cochino12
It followed me home?
cochino12's Avatar
just depends on the truck, my yellow 85 was lowered 6" and only bottomed out a couple times in 6 years but my 77 2wd blazer I had to notch asap before I knocked teeth out.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-06-2009, 02:10 AM   #4
83_383Stroker
would i be better off in the long run by going with a spindle+spring combo for the front?
Old 01-06-2009, 02:57 AM   #5
Malo83
Cruzzzn' Vet
Malo83's Avatar
Yes, and you don't need a C-notch with the flip kit
Malo83 is offline   Reply With Quote
Old 01-06-2009, 09:55 AM   #6
vonlefty
Unless your springs and/or shocks are worn out. It probably won't bottom out unless you haul more than a couple 2x4 and some plywood or you want to tow something but the difference in price is only $70. Buy the kit with the c-notch, use the truck for awhile without the notch installed, if you don't need it I'll buy it from you.
vonlefty is offline   Reply With Quote
Old 01-06-2009, 11:34 AM   #7
Cherub
Cherub's Avatar
I have yet to drive with my cnotch on but it looks like if you plan on towing anything you will need it for clearance.
Cherub is offline   Reply With Quote
Old 01-06-2009, 11:49 AM   #8
83_383Stroker
the most i would ever have in it is my Honda TRX400EX and thats like maybe 3-4 times a summer to go to the dam and ride. but no towing i don't even have a bumper for a ball. (roll pan)
Old 01-06-2009, 12:55 PM   #9
87c10slammer
truck addict
i would go with the notch... i dont know where you live but if you hit one good pothole your looking at alot of shattered teeth... its better off in the long run f you notch it now and dont have to worry about it
87c10slammer is offline   Reply With Quote
Old 01-06-2009, 04:56 PM   #10
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Generally I recommend one for anything over 5"
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
