Old 01-06-2009, 07:58 PM   #1
72' Jimmy
3/4 ton axles
Found some 3/4 ton axles with 4.10s, Dana 44 and corp. full floater 14 bolt for $275. Is this worth it? I have 3.73s now and running 35's but want to run 37's would 4.10 work?
72' Jimmy is offline   Reply With Quote
Old 01-06-2009, 08:09 PM   #2
AJs72K5
AJs72K5's Avatar
Re: 3/4 ton axles
Unless you're going for mpg, I think you'd be undergearded at 4.10s with 37s. You'd be better off with 4.56s.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 01-06-2009, 08:17 PM   #3
DANTES JIMMY
DANTES JIMMY's Avatar
Re: 3/4 ton axles
I agree with aj
but to answer the question
that sounds like a good price
to me if there arent any probs with them
at least in these parts thats a good deal
DANTES JIMMY is offline   Reply With Quote
Old 01-06-2009, 11:02 PM   #4
1tuff71
1tuff71's Avatar
Re: 3/4 ton axles
Thats a great deal on those axles. Even if they need a rebuild. Grab'em!
1tuff71 is offline   Reply With Quote
Old 01-06-2009, 11:11 PM   #5
AJs72K5
AJs72K5's Avatar
Re: 3/4 ton axles
Keep in mind that if it is a 14FF and not a 14SF, the spring perches will need to be cut off and moved as well as the shock mounts. It's not a direct bolt in.
To answer your original question (sorry), that's a decent price, if they're complete and don't need major work. You won't be any worse off with 37s and 4.10s than you are currently with 3.73s and 35s.
- AJ
Old 01-07-2009, 01:49 AM   #6
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Re: 3/4 ton axles
Won't the 14SF will still require shock mount relocation? Are the spring perches on the 14SF located correctly for our trucks?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 01-07-2009, 06:44 AM   #7
vtblazer
vtblazer's Avatar
Re: 3/4 ton axles
Find a gear chart on-line, that will help you find the RPM's you'll be running @ speed and allow for a better decision to be made on your part.
Thought the 14FF only needs shock mounts changed...
vtblazer is offline   Reply With Quote
Old 01-07-2009, 10:52 AM   #8
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: 3/4 ton axles
Only if it's from a one ton. 3/4 ton 14 bolts need everything relocated if it's going in a 1st gen. If it's a 2nd or 3rd gen blazer the 3/4 ton 14 bolt is a bolt in (at least as far as spring perches go).
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 01-07-2009, 11:06 AM   #9
vtblazer
vtblazer's Avatar
Re: 3/4 ton axles
Good to know, thanks.
Those 14BFF's really get around.
Old 01-08-2009, 03:40 PM   #10
72' Jimmy
Re: 3/4 ton axles
Thanks for your help. I will pick them up. I guess run the gears it has in it until I have enough money to run 4.56's.
Old 01-09-2009, 11:38 PM   #11
Rider
Re: 3/4 ton axles
The dana 44 is still a half ton front axle with eight lug bolts which is what you already have accept yours has six lugs. Dana 60 is what you want in the front, the axles are much l;arger.
Rider is offline   Reply With Quote
