01-07-2009, 08:09 AM | #1 |
Later Steering Box Swap?
What year steering box is a good upgrade that bolts right on?I know the ratio became quicker at some point.Then,after a few years or so the hose fittings went metric.Did 2wd and 4wds change in the same years?I not,when did each change?
01-07-2009, 08:49 AM | #2 |
Re: Later Steering Box Swap?
Tim, I think 78 is the good year for the quick boxes. I think the early 80's went to metric fittings. You know someone else will confirm this or not. Thought I read about this some time back on here.
1997 GMC Sierra Ext 1965 Mustang |
01-07-2009, 10:34 AM | #3 |
Son of a gun
Tim, 78 will have the variable ratio and the fittings to use 68-72 hoses. I believe it would be the same from 78-80.
I edited this to read 78, should have said 78, not 76!!!
Bill BEATERS ARE NEATER Last edited by Bus Ted Knuckle; 01-07-2009 at 10:01 PM. Reason: I said 76, and meant 78! |
01-07-2009, 02:59 PM | #4 |
We used a 1978 box to fix a leaking one on our 71 C20. Lines fit just fine, just had to use the rag joint from the 1978 with the 1978 box because the splines are different than the older box. It does turn faster than the old box.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
01-07-2009, 04:01 PM | #5 |
I'm a poor spectator
This is good to know. Is it the same for a 4x4 though. I know 4x4 boxes are unique to 4x4's but do 76 and up boxes for 4x4's have a quicker ratio??
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
01-07-2009, 04:58 PM | #6 |
That`s what I`d like to know,too.I want all the lowdown so there`s no confusion.If there`s not a FAQ thread maybe this can be a candidate.I know when I bought a box from GM for my`71 the part went through`77.I don`t know if that`s when they changed the ratio,changed the spline at the rag joint,or maybe went metric.I was thinking try`78 because I`m thinking I may rememeber metric stuff showing up on a buddy`s truck.
01-07-2009, 07:20 PM | #7 |
ASE master tech/machinist
77-79 4x4 trucks had the fast ratio units. I ran several of them for a while in my 79 mud truck, the stock box would turn my 44's just as good as my friends AGR piece. They were prone leakage for some reason, I never figured it out. Those boxes teamed with a 78 WS-6 trans am pump make excellent off road pieces.
"I sit here and I pray in my broken down Chevrolet....." |
01-07-2009, 08:05 PM | #8 |
Great info so far.I`m thinking the through`77 was about the spline and rag-joint changing.My replacement (2wd) is most likely the later quick ratio.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-07-2009 at 10:06 PM. |
01-07-2009, 08:45 PM | #9 |
Just subscribing. Interested in any info of this type too. (My 72 could use a better steering box).
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
01-07-2009, 11:15 PM | #10 |
My bro and I swapped a power box from a 76 2wd onto his 72 2wd that was origianlly manual a few yrs back (20?!?!) w/ no problems. Same splines and fittings on both.
