Old 01-09-2009, 12:43 AM   #1
smoked68
smoked68's Avatar
Oil pan removal in 68 SB
Quick questions. Do I need to raise or pull the engine to get the oil pan off, (replacing the pump)?. Also where to get the one piece pan gasket?? and lastly should I go 10% or 25% more on the pump??? thanks and have a good day, Mike...
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 01-09-2009, 01:06 AM   #2
project 67 sub
project 67 sub's Avatar
Re: Oil pan removal in 68 SB
yes, you need to altleast raise up the engine. might be easier and quicker to just pull the motor though. you can also get a one piece pan gasket from your local autozone etc.
project 67 sub is offline   Reply With Quote
