Old 01-10-2009, 10:40 AM   #1
mrhino
whats the diffrence
I was looking at buying this 62 c10, but dont know much about them, my question is: what is the diffrence between them and 63 and up as far as the chassis. (i.e. brakes, steering, suspension front and rear. Thanks
mrhino is offline   Reply With Quote
Old 01-10-2009, 10:53 AM   #2
joe231
joe231's Avatar
Re: whats the diffrence
the '60-'62 has a X frame and torsion bars up front. stock suspension parts are spendy, but you can swap in an '73-up cross member.
the '63-'66 and '67-'72 suspensions are pretty much alike, and you can just change to '73-up arms to have disc brakes and updated suspension.
And
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-10-2009, 11:22 AM   #3
mrhino
Thank you for the info, that's exactly what I wanted to know.
Old 01-10-2009, 12:05 PM   #4
Demmit_Hemmit's 65
Demmit_Hemmit's 65's Avatar
Welcome from a fellow hoosier................Hemmit
Demmit_Hemmit's 65 is offline   Reply With Quote
Old 01-10-2009, 12:26 PM   #5
slepysal
slepysal's Avatar
60-62 also have a different rear end, so swaping in a 5 lugger takes some fab work,also if yours is a stick it has a hydrulic clutch that is feed by your master cylinder ( brake/clutch) so when updating your brakes this has to be modified too .
No biggie . Nice truck and welcome from SAN JOSE Nor*Cal
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 01-10-2009, 12:59 PM   #6
502tripower
502tripower's Avatar
What is the difference on the rear? Is it the perches or panhard or both? Is it because the 60-62 frames are wider and the angle of the trailing arms?
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 01-10-2009, 05:32 PM   #7
slepysal
slepysal's Avatar
both, the perches are spaced different and the panhard bar is longer . Both are ez fixes if you have a torch and welding skills , both of which I dont lol
Old 01-10-2009, 08:04 PM   #8
502tripower
Thought that was it...Thanks
98' FXD
2002 2500HD
