windshield removal..
dad came to see what progress i have made on my truck... and once all my body work/sheet metal is done.. i want to clean up my orange paint it looks just like surface rust starting its just discolor in my white paint..so i want to remove the windshield.. and mr windshield a place here in town wants like 80 bucks to get it out..i would like to save some money so does anybody have some tips?
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
Old member
Re: windshield removal..
No matter how you take it out replace the gasket with a new one no matter what. With that said cut the rubber gasket and take it out. Takes a good razor knife and about 15 minutes. Buy a new one to reinstall.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Too many projects
Yep, just take a razor blade and cut down through the center along the edge of the glass and peel off the gasket and have a buddy push on the inside and it will pop right out. You need a new gasket, but like has been said, you need it anyways.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
![]() Join Date: Aug 2008
I removed one from a '71 I am parting out by myself by installing a NEW blade in the utility knife, cutting the rubber from the inside til I saw the edge of the windshield opening, then it almost fell out on its own. Be careful pushing very much. If it is still in a bind anywhere, it will crack the windshield.
how do i take of the chrome trim around the windshield without bending it
![]() Join Date: Jan 2008
gotta take the windshield out first. then just remove the seal/trim.
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 ![]() http://i195.photobucket.com/albums/z...en58/001-2.jpg |
took trim off first...bent it to heck...but oh well its all good...good reason to tell dad i need new ones haha... i got windshield out and cleaned up the surface rust today
