01-12-2009, 02:21 AM | #1 |
61 3/4 ton to 1/2 ton questions
My buddy was given a 1961 3/4 ton. He wants to make a shortbed out of it and thats no problem but what all do i have to do to convert it from 3/4 ton to 1/2 ton? He said it has coi springs and the trailing arms in the rear with some sorta half a leaf helper spring. Can we just put a 1/2 ton diff. under there with regular springs? The front will most likely get swapped for a 73-87 crossmember and we will remove the X frame and box the frame a little more. He doesn`t know much about these trucks so I`ll most liley be doing most of the work. Funny thing is he`s the one that got me into hot rods 20 years ago and now he dosn`t even know where to start,lol. Help me out guys.
Anthony |
01-12-2009, 02:40 AM | #2 |
60-66 Nut
Re: 61 3/4 ton to 1/2 ton questions
Sounds like you've got the front figured out. For the rear, I would get a 12 bolt out of a '63-'70 1/2 ton and just get the conversion axles, or re-drill the flanges. You'll have to move the trailing arm pads out and re-weld them since the '60-'62's are wider. If you get a rear diff out of a '71-'87, keep in mind that they are 1.5" wider overall.
Sounds like it has over load springs on it(half leaf spring).....I'd just remove them.
01-12-2009, 02:54 AM | #3 | |
Anthony |
