Old 01-13-2009, 05:49 AM   #1
67neverdone
Big Block Oil Pan Removal Question
I have a '71 Chevy C/30 Longhorn with the 396/turbo 400 setup in it. It has factory air and power steering. My question is, I need to change the oil pump in it and I was wondering if it is possible to get the oil pan off and swap the pump without pulling the engine? Is there enough clearance around the crossmember, etc? It looks like there might be, but I have learned that looks can be deceiving... Thanks in advance for your help.
67neverdone is offline   Reply With Quote
Old 01-13-2009, 10:36 AM   #2
airdale94
airdale94's Avatar
Re: Big Block Oil Pan Removal Question
Don't know for sure but you can always try rotating the crankshaft so the front journal (balance) is up. You can get some clearance also by undoing your trans. mount and jacking up the rear of the trans. Trans. mounts are easier to get back aligned than eng. mounts.
airdale94 is offline   Reply With Quote
