Old 01-11-2009, 02:41 AM   #26
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
Re: Master Battery Disconnect Switch Placement
hmm never saw the "extra power lead" batt cut off switches... also interested where you can find these...
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 01-11-2009, 03:05 AM   #27
extd56
extd56's Avatar
Here are a couple
http://www.watsons-streetworks.com/battery.html
extd56 is offline   Reply With Quote
Old 01-14-2009, 08:20 PM   #28
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Originally Posted by texanidiot25 View Post
So you guys are putting this on the positive side of the battery? When I thought about it, I was looking at the ground cable, but maybe that's because I run things off a fuse block already on the battery..
And what ones have the extra power lead?
You could run the switch off the negative battery but you would not be able to run a bypass to anything because the ground is common to all circuits and as soon as you turned the key all circuits would be activated. The first time you forgot to turn on the switch and you hit the key to start the engine you'd fry that little wire.
You don't need an extra terminal just run your wire from the battery cable side of the switch to whatever you want to be powered all the time.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-14-2009, 11:24 PM   #29
lts70
1970 Daily Driver
lts70's Avatar
That is what I did on mine. The ones with an extra terminal cost more and unless you have a crap load of things you run strait off of your battery there is no need for it. Save the money and run your alarm and stereo memory off the battery side of the switch as VetteVet said.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 01-14-2009, 11:50 PM   #30
texanidiot25
Eat My Rust
texanidiot25's Avatar
I have an extra fuse block, that's the issue. I'd have to go look at my truck and remember how everything gets power again.
texanidiot25 is offline   Reply With Quote
Old 01-16-2009, 01:16 AM   #31
orbot
orbot's Avatar
Heres a question.
Can i just hook the switch directly to the starter's "S" post so i can manage its function and also keep the radios and everything else intact??
orbot is offline   Reply With Quote
Old 01-16-2009, 02:52 AM   #32
70cst
70cst's Avatar
Well....after reading this thread and doing a lot of Googling I ended up purchasing the Watson's PressTech TM Touch Pad Battery Disconnect. This way I can install the "Touch Pad" inside the cab someplace out of sight. This has been a great thread.Thanks guys for all the input.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-16-2009, 06:43 AM   #33
jaros44sr
jaros44sr's Avatar
Thanks for the link, that is way cool and on my wish list...great thread, lots of valuable info
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-16-2009, 08:25 AM   #34
70cst
70cst's Avatar
lts70 ...I gave you a reputation. Great thread and very useful.
Old 03-07-2016, 04:45 PM   #35
88Stanger
88Stanger's Avatar
I know this thread is old, but this is a good idea. Thanks
88Stanger is offline   Reply With Quote
Old 03-07-2016, 11:15 PM   #36
89AKurt
89AKurt's Avatar
I was wondering about the same thing, thanks for resurrecting 88Stanger.
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
Old 03-08-2016, 01:50 AM   #37
88Stanger
88Stanger's Avatar
so i was talking to a good friend of mine and he suggested that maybe we also install a battery tender permanently, just under the battery, 5amp one that is water proof. This would be for long winter storage and such, i thought it sounds like a good idea.
Old 03-08-2016, 01:27 PM   #38
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Master Battery Disconnect Switch Placement
I have a battery shut off on my 71 but it's on the negative cable. I have been seeing my tach and lights deeming at night since I installed it. I have been thinking about a upgraded alternator and a capacitor for the amp I run.
I went by my local Stereo Store yesterday and he said remove the cut off and see what happens.
This is my goal for the day.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
