Old 01-14-2009, 09:34 PM   #1
drewfever1020
im really angry whats going on?
ok i got home and installed my aftermarket oil pressure gauge.
so i turned on my truck to go put gas and as im going i noticed my fuel and my speedometer gauge not working, so i chekd my light and no lights on the dash but my light are working outside. so i think its afuse so i check the fuses and they are good!
so whats going on? im gettin angry now i cant see how fast im going now!
drewfever1020 is offline   Reply With Quote
Old 01-14-2009, 09:36 PM   #2
hilandr452
hilandr452's Avatar
Re: im really pissed whats going on?
I'm thinking maybe you unplugged the wiring harness to the instrument panel?
Dan Smith
Colorado Springs, CO
71 GMC Custom Camper "Longhorn" 454, TH400
73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny
"DON'T TREAD ON ME !!!"
My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442
hilandr452 is offline   Reply With Quote
Old 01-14-2009, 09:40 PM   #3
drewfever1020
no its plugged in
Old 01-14-2009, 09:46 PM   #4
Green Machine
Green Machine's Avatar
Gauges not working, or you can't see them because the dash lights don't work ?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 01-14-2009, 09:58 PM   #5
drewfever1020
there not working at all!
they were fine then all of a sudden, i think i have a short in my truck!
were can i get a complete harness for my truck?
its a 71
Old 01-14-2009, 10:10 PM   #6
70clone
70clone's Avatar
try wiggling the headlight switch also turn the knob back and forth a few times
70clone is offline   Reply With Quote
Old 01-14-2009, 10:11 PM   #7
Green Machine
Speedometer is all mechanical, that should still work even if you unhooked all the wires. Gas guage has a brown wire that goes to the tank sender, check that and make sure it is plugged into the correct place in the fuse block.
Old 01-14-2009, 10:16 PM   #8
drewfever1020
i tried that!
when i turn my lights on my fuel gauges moves to empty but its not working at all!
not even my speedometer
Old 01-14-2009, 10:17 PM   #9
drewfever1020
my speedometer aint working at all!
the gas sending unit is plugged rite and still nothing
Old 01-14-2009, 10:22 PM   #10
4x4s4allie
4x4s4allie's Avatar
my truck does the same, but mice found my truck their home for awhile ... take apart your dash, make sure your wires aren't crossed ... that will cause what you're saying ... also, try turning your headlight switch ALL the way to the right ... that's what i've gotta do for my dash lights and gauges to work ... but that was after i straightened some wires out ...
1948 CJ-2A Jeep 3spd
1961 C2500 305 V6 4spd
1967 C-10 Long Fleetside
1968 C-10 Long Stepside 250 Saginaw 3spd
1978 Scottsdale K10 355 4spd
1983 Honda Shadow VT750
1990 Toyota 4Runner SR5 4x4 5spd
2008 Toyota Yaris
1978 Scottsdale K10 355 4spd the "Ruby Build"
4x4s4allie is offline   Reply With Quote
Old 01-14-2009, 10:33 PM   #11
drewfever1020
how can i turn my switch to the rite if it doesnt even go that way
Old 01-14-2009, 11:26 PM   #12
Green Machine
Well if you are really pissed, you need to calm down, because you will never get anything done being pissed. Having said that, you have three problems here. 1. gas gauge not working. 2. dash light not working. 3. Speedo not working.
Take the easy one first. I suspect the speedometer cable is either broken or unhooked at one end or the other. If the cable is not broken, unscrew it from the speedometer head, drive down the street very carefully, and check to see if the cable is spining with your fingers. If the cable spins then the speedo head is bad, if no spin,then there is a problem with one of the speedo gears in the tranny.
Do you have park lights ? I think they run off the same circut as the dash lights. I also suspect a bad ground the gauge cluster. Remove the plug to the cluster, and make sure it is clean and in properly.
Old 01-14-2009, 11:33 PM   #13
lts70
1970 Daily Driver
lts70's Avatar
Originally Posted by drewfever1020 View Post
i tried that!
The speedo not working is a completely different issue from the fuel or any other gauge,they are not related. Make sure you screwed your speedo cable all of the way on and that it is not cross threaded.If it is you have possibly snapped your speedo cable.
Double check your where your wire harness plugs into your gauge cluster. make sure it is all of the way plugged in and not cock-eyed or reversed.
Good Luck.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 01-15-2009, 12:34 AM   #14
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you need to ground the panel. The fact that the fuel guage moves when you hit the lights tells me this.
Your speedo issue is due to either not being hooked up, being broken, or, when you screwed it back on,you didn't get the cable into the hole properly and it never actually plugged in.
Old 01-15-2009, 09:06 AM   #15
People tend to get angry about what they don`t understand.Did you take the dash back out and inspect when this happened or get made because it didn`t go right the irst time.I`ve never seen a mechanic get mad until at least after he`s gone back over his work.The headlights and instrument lights are different circuits.Prolly a ground as mentioned.
Old 01-15-2009, 09:09 AM   #16
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
X2 you need to ground the panel. Thats what I was going to say the ground wire might have came off...
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 01-15-2009, 09:19 AM   #17
drewfever1020
Re: im really angry whats going on?
i will check my ground when i get back from work!
Old 01-15-2009, 04:58 PM   #18
Longhorn Man
just add one. The factory ground clip was probably left off 20 years ago and they got lucky. Just put a lenth of wire on there with eyelets on either end. Secure one to a bolt on the back of the panel, and then slip the other end under one of the screws that holds the panel to the dash.
Old 01-15-2009, 06:04 PM   #19
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Whenever you take a cluster out,always look at the male (cluster side of the connection) and take an eraser (pencil eraser) and gently rub the contacts.This will clean them and make for a better connection.Whe you plug it back in make sure you plug it straight and get it to lock in all the way.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-15-2009, 06:51 PM   #20
drewfever1020
were is the ground wire located?
Old 01-15-2009, 07:38 PM   #21
s_nova69
Ya definatley the ground. My ol 72 had the same problem til i found the dangling ground one day.
s_nova69 is offline   Reply With Quote
Old 01-17-2009, 05:17 PM   #22
drewfever1020
i put a new ground but the fuel gauge goes up and down sometimes ut it seems to be working!
why wont my panel lights work?
Old 01-18-2009, 11:39 AM   #23
Dark Knight
Dark Knight's Avatar
Hi drewfever1020. I just went through this problem a few days ago. The problem is your headlight switch. (At least it was for mine). Go to your local auto parts store and pick up a new one. They're under $20. Pop it in and your problems should be solved. My Delco-Remy stayed in there for 42 years, but they just don't last forever. Hope this works for you.
Dark Knight is offline   Reply With Quote
Old 01-18-2009, 07:12 PM   #24
Longhorn Man
a new switch would be next assuming you are 100% sure the bulbs are good.
