Old 01-15-2009, 05:06 PM   #1
63Belair
78 to 63 steering column swap
I'm sure this is addressed some place here that I can't find but we've completed installing a 78 chev steering column in a 63. I've looked over wiring diagrams for both the 78 and the 63 and can't seem to place 2 of the 7 wires. Any one done this swap?
63Belair is offline   Reply With Quote
Old 01-15-2009, 05:10 PM   #2
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: 78 to 63 steering column swap
I swapped a 77 into a 66, but I used the 77 wiring harness.
Joey~AP is offline   Reply With Quote
Old 01-15-2009, 05:55 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
What wires? I think the newer columns had more acc power. Im guessing as I have been straightening out this swap in my 'burb; done by PO.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-15-2009, 08:05 PM   #4
63Belair
There are 7 wires coming to each pigtail. The wire harness from the 78 column
has 7 and the 63 pigtail from the main dash harness has 7. They are for the directional signals, stop light, haz light and a seperate black for the horn. I was just going to cut the connections off the ends of each group of wires and tin them together if I can find the correct combination. The wire colors are different.
Old 01-15-2009, 11:33 PM   #5
protrash64
protrash64's Avatar
I think all will work correctly, as the functions of the old and new harness are the same. I would crimp on spade connectors and hook it up; if you have any bad or crossed connections you can just unplug them and try a new combo....test it and get it right.
Old 01-16-2009, 01:50 AM   #6
joe231
joe231's Avatar
here is a 64 diagram
green(right) and yellow(left) are rear turn/brake wires
dark blue(right) and light blue(left) are front turn
white goes to the stop lamp switch
brown goes to the horn
purple goes to the turn flasher
maybe that is close to your '63 wiring?
i have a pdf file for my '80 (should be the same as a '78)
brown is hazard flasher(you won't need)
black is horn
1980 wrg diag 01.pdf
1980 wrg diag 02.pdf
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 02-17-2009, 05:52 PM   #7
63Belair
Thanks, I think I got it. I've been working off a wiring diagram from my 63 Belair which is the same as the 64 pick-up diagram posted here.
