01-14-2009, 06:03 PM | #1 |
Battery Master Power Switch Lists
I have been reading threads on Battery Switches and ran across this. Its a little pricey but.... What do you all think? The good and the bad?
Paragon Products $199 http://www.paragon-products.com/prod...r%20switch.htm This is painless...$79 http://www.vichubbard.com/auto-part-...ppp-30204.html Hotronics...about $25-20 http://www.streetrodderweb.com/tech/...ect/index.html Cole Hersee $20-25 http://www.ryderfleetproducts.com/cg...uct_detail.jsp Watsons $110 http://www.watsons-streetworks.com/battery.html
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 01-14-2009 at 08:57 PM. |
01-14-2009, 06:20 PM | #2 |
1970 Daily Driver
Re: Battery Master Power Switch
Look at this site. Cool idea.
http://www.watsons-streetworks.com/battery.html I just did the old school switch version. http://67-72chevytrucks.com/vboard/s...d.php?t=321757
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 01-14-2009 at 06:23 PM. |
01-14-2009, 06:32 PM | #3 |
One thing I noticed is the range of amperage ratings between the switches.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 01-14-2009 at 06:32 PM. |
01-14-2009, 08:56 PM | #4 | |
Thanks...I added it to my list.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-14-2009, 09:00 PM | #5 |
sharp as a marble
Re: Battery Master Power Switch Lists
what are you trying to accomplish? Look at painless wirings web site. They have a couple of setups that would allow you to use a toggle switch, from under the dash to shut down the whole electrical system, but yet retain memory to what you want. I looke at this the other day 70107 is the part number I think?
01-14-2009, 09:38 PM | #6 |
Just looking at the cleanest options avaliable. Also I have noticed that there is a wide range of amperage ratings. There is another thread which touches on this subject so I thought it would be good to see what viable options are out there. I think I like the Watson and Painless best of the ones so far. I will end up installing one of these on the Circuit Rider. I only want to do this once.
01-14-2009, 11:51 PM | #7 |
I'm running the Watson switch in three of my vehicles.
One activated with a remote and the other two with buttons. Even the tech guys at Watson's are helpful. I'll buy from them again. Mick |
01-14-2009, 11:59 PM | #8 |
Eat My Rust
70-80 amp should be a pretty safe set unless your running a sound system. Most modern seem to run around that I've noticed.
01-15-2009, 08:53 AM | #9 | ||
01-15-2009, 06:20 PM | #10 |
Ok...after much reading and googling....I went with the Watson's PressTech TM Touch Pad Battery Disconnect. It looked like the most flexable plus they were very helpful on the phone.
