Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-12-2009, 04:13 PM   #476
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: Building a Blazer - vtblazer's Way
Originally Posted by vtblazer View Post
When I had the U-bolts made up, I asked em to add an inch in total, just incase I run a thicker spring pack.
Problem is, I'm not sure they threaded them low enough.
Tie Rod color...? Guess I had that one coming didn't I?
I noticed that, hopefully you can make it work and not have to buy new ones. As for the color I was serious but now that ya mention it, thats pretty funny... How about purple. .
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 01-12-2009, 07:36 PM   #477
vtblazer
vtblazer's Avatar
When I spoke to Ballistic on Fri and they told me the parts still hadn't shipped, I asked them if they'd ship em out 2nd day air for me since they were so late and he said okay.
Well he did what he said, they arrived today.
Turns out the TR ends on my cross over are larger, might be able to get the one end machined out hopefully.
Also turns out that the factory TR has the correct ends, so if I can get enough adjustment out of it, I can use it and I get my high steer too.
vtblazer is offline   Reply With Quote
Old 01-12-2009, 07:58 PM   #478
RED72blazer
urban fourwheelin
RED72blazer's Avatar
I'm assuming that the new drag link connects to the box and the old one is connecting the knuckles. Other than the obvious, the draglink is no longer hanging out front and subject to damage.. Is the way you are doing your steering make the truck drive better?
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 01-12-2009, 08:51 PM   #479
vtblazer
vtblazer's Avatar
Correct, The newer looking rod/bar (drag link) goes from a 2wd steering box and crosses over to the passenger side knuckle which now has a steering arm.
The cross over set up is what will make it drive better, the high steer is a side benefit.
Old 01-13-2009, 12:26 AM   #480
RED72blazer
urban fourwheelin
would I see much of a benefit with crossover and 33 inch tires?
Old 01-13-2009, 06:34 AM   #481
vtblazer
vtblazer's Avatar
No.
Cross over is only really appicable when you get into bigger tires (36+) or around 6"s or more of lift.
(mainly the lift issue)
Are you running a D60?
Old 01-13-2009, 10:37 AM   #482
hgs_notes
GEARHEAD
hgs_notes's Avatar
Does cross-over steering improve turning radius at all? Are there other tricks used to improve turning radius?
hgs_notes is offline   Reply With Quote
Old 01-13-2009, 03:31 PM   #483
RED72blazer
urban fourwheelin
No.
No, D60 here. i'm 5'8 and my lady is 5'2 on a good day. so My truck won't ever get bigger than 33 and I only do light logging road wheeling. So I will be sticking with the dana 44. I was just curious if it would help my truck handle a little better.
Old 01-16-2009, 07:18 AM   #484
vtblazer
vtblazer's Avatar
Axle is done and it's at least a roller again.
It's currently having to share the space, those 37's don't seem to look so big anymore...
The interesting part is, how can one blazer with 37's & 2.5" springs, sit just as high as one with 42's & 6"s of lift?
Old 01-16-2009, 07:23 AM   #485
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Cool pics! Wish I had two of 'em.
What am I talking about...I can't find the time to work on one.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 01-16-2009, 07:28 AM   #486
jaros44sr
jaros44sr's Avatar
That could be the question of the day, actually the orange one sits 1"-2" higher from the first pic
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-16-2009, 07:46 AM   #487
vtblazer
vtblazer's Avatar
Give it time, you'll get there.
Two is a lot, this could change in the coming months.
Initially the tires on the blue blazer were pretty 'aired down' lets say but even when I pumped em back up, there's not a whole lot of difference between the two as far as sitting static.
Old 01-16-2009, 07:59 AM   #488
jaros44sr
jaros44sr's Avatar
extra wt. and sagging springs on the blue one??
SAFETY FIRST
AS usual, off topic
Jim
Old 01-16-2009, 09:03 AM   #489
vtblazer
vtblazer's Avatar
Potentially, all the above I guess.
Old 01-16-2009, 09:13 AM   #490
Bentblazer
Bentblazer's Avatar
Neat way to fill up a shop
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 01-16-2009, 09:29 AM   #491
vtblazer
vtblazer's Avatar
*Full* - ya got that right!
Less than 2ft all around, that's all the walking room that's left.
Old 01-16-2009, 09:56 AM   #492
jaros44sr
jaros44sr's Avatar
Now your down to my level, but way cool to have them in YOUR shop. Maybe time to reorganize, relocate workbench to basement?
SAFETY FIRST
AS usual, off topic
Jim
Old 01-16-2009, 09:59 AM   #493
Burt4x4
Burt4x4's Avatar
DeeeeLishous
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-16-2009, 11:21 AM   #494
4bynut
4bynut's Avatar
Is 2.5" the exact lift on the front of the red one? You have a shackle lift on the rear which should be 4" or more and it looks to be sitting level. Just curious.
BTW. They look good in there together. I'm glad the ballistic arm showed up finally. The H2 rims look good to. I always like the way they look on the older trucks.
Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans.
2001 Chevy ZR2 Ext. cab 4x4 (DD)
1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process)
1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project)
4bynut is offline   Reply With Quote
Old 01-16-2009, 05:27 PM   #495
Big J
Big J's Avatar
I think its time to add on to your garage. Maybe a "lean to" to park under.
and what does this mean? "Two is a lot, this could change in the coming months." Sellin' the fun truck?
BAZINGA!
My Build
Old 01-16-2009, 06:17 PM   #496
vtblazer
vtblazer's Avatar
Like anybody would buy it!
Old 01-16-2009, 07:21 PM   #497
Big J
Big J's Avatar
You kiddin'. I'd be honored to own it. I'd have a ball around here with one built like that. But I'm broke so no I couldn't buy it. Donations however are always welcome.
BAZINGA!
My Build
Old 01-16-2009, 08:21 PM   #498
FormerMember
Remember, per our agreement, you give me first shot at getting it back.
Hopefully, if that happens, cash is a little more readily on hand!
FormerMember is offline   Reply With Quote
Old 01-16-2009, 09:20 PM   #499
vtblazer
vtblazer's Avatar
It'd be a tough choice but if the one I'm building now turns out as planned, ya never know.
You'll be the first to know, as per our agreement.
You want it before or after the taper job?
Old 01-17-2009, 09:04 AM   #500
FormerMember
Hmn, not sure. Certainly not ready now!
