Old 01-16-2009, 12:36 AM   #1
tim21391
tim21391's Avatar
how to plug oil pressure line
i took my gauges out to install a white face gauge kit.. and the truck is getting a color change so they are out and i pulled truck out and i come back and i gotta puddle of oil by the driver pedal...how do i plug this so i dont leak when i want the engine to run because while the truck sits while we fix the rust and get it painted i dont want the carb to gum up
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 01-16-2009, 12:42 AM   #2
cdowns
cdowns's Avatar
Re: how to plug oil pressure line
take the fitting out of the block and put a plug in it
Old 01-16-2009, 12:43 AM   #3
El Jay
Gone to greener pastures
You could probably pull the fitting @ the back of the block & put in a pipe plug.
Should be 1/8", I believe.
That way nothing gets bent up, or crimped in the cab.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 01-16-2009, 12:45 AM   #4
El Jay
Awwwwwww, Man,
You posted while I was typing, that ain't fair.
Old 01-16-2009, 12:46 AM   #5
Brock396
remove the other end of the line from the block and install a npt pug
Brock396
Brock396 is offline   Reply With Quote
Old 01-16-2009, 12:49 AM   #6
Brock396
thats ok. two people posted while i was typeing
Old 01-16-2009, 12:51 AM   #7
tim21391
tim21391's Avatar
oh ok well it ran for 5 minutes so it should be good for another week or two.. now would be a good time for me to sand where it was
Old 01-16-2009, 08:57 AM   #8
71tahoe
71tahoe's Avatar
I've never had a plug when I needed it but I did have an extra gauge. Very handy when you prime the engine before you start if for the first time after rebuild too.
71tahoe is offline   Reply With Quote
Old 01-16-2009, 12:28 PM   #9
lts70
1970 Daily Driver
lts70's Avatar
That what I do as well. I have an extra oil gauge that I just screw on in the cab after I take out my cluster.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
