C10 Club Tennessee
Installing Super Track Bar with Bags
This may be a stupid question, but I was trying to install my CPP super Track Bar kit and can't seem to get it right. It wasn't off but about 1/2 to 3/4 of an inch in the first place, but I wanted to try to get it perfect. I worked for a few hours on it and thought I had it. I tightened everything down and dropped it and IT WAS OFF MORE THEN IT WAS IN THE FIRST PLACE!!!!!!!!!!!
Any secrets to this??
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
A guy with a truck
Re: Installing Super Track Bar with Bags
Are you trying to center the rear? It will only be centered at one point in the suspension's travel. I set mine for ride height. It will move to one side or the other when aired up or down. It's basically trial and error- I wish they were threaded on both ends ala tie rods- would make life a lot easier...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
C10 Club Tennessee
yes, I was trying to get it centered when it's aired out, but you are saying it's not going to happen?
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 12-24-2008 at 09:48 AM. |
A guy with a truck
Maybe not. There may not be enough adjustability in it. I center mine at ride height so that 1) it will not rub any where while driving 2) it will not dog leg or crab walk down the road.
C10 Club Tennessee
Okay, I'll play with it again. Was just so mad after 3 hours of up and down, up and down. Got it on schrader(sp?) valves until the wiring is done.
It's Better With Nitro
...as gringoloco mentioned, it's best to make the adjustments to the track bar at ride height because it will push the rearend out/in depending on where in the suspension travel you're at. I had a similar problem you have...then I had to break out the geometry and do some math, which mad me even more upset.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 12-24-2008 at 11:06 AM. |
67-72 parts collector,…
![]() Join Date: Nov 2002
vin63,... thanks for the picture.
I'm in the process of making the same type of modified bracket. 5150,... put your truck up on jackstands (under the rearend) and use a come-a-long or ratchet straps to center the frame. (basically pulling the frame/body left to right until you have it centered). Then thread out the track bar end until it bolts up. Air it up and down while its on the jackstands to check for rubbing/ side movement.
vin63 info on that sway bar set up been lookin at that option myself just wondering what or who you got it from. Thanks for your time
VA72C10
![]() Join Date: Mar 2008
So would you recommend the super trac bar kit or just a simple adj. track bar and making your own bracket for someone w/ bags on trailing arms?
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Don't mean to hijack...I went with a torsion-style sway bar because of the issues I was having with the track bar and how low the truck was with the air bags. The 36-spline torsion bar and arms were leftover from an earlier project (Speedway Engineering). I used a 1 1/8" tube as a housing/crossmember and used spherical rod ends to the rearend housing.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
GM ONLY BABY!!!
Hmmm, interesting, I am getting ready to frameswap my 72 GMC onto a 71 Chevy frame so that I can install the airbags on the rear. I will be installing a c-notch and blocks, and adj. trac bar. I wanna watch this one. Lets see some more pics and options/opinions.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
VA72C10
ttt
#13 | |
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 01-14-2009 at 12:28 PM. |
A trac bar is such a simple concept and it is nothing like a pan hard bar. I have used trac bars with every vehicle i have ever bagged and never had any side to side movement. It all depends on how u set up your trac bar. If you mount the trac bar diagonally from one link bar to the other and not to the frame it will not move side to side. You start to get side to side movement when you mount one side to the frame and the other side to the rear end or link bar. If you look at the trac bar in the picture you will see it runs from one link bar to the other.
#15 | |
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 01-16-2009 at 11:02 AM. |
#16 | |
Señor Member
![]() Also, the term "Trac Bar" as it's being used in this thread, is indeed a Panhard rod that is longer than the stock unit. The longer unit allows for less side-to-side motion of the rearend as the suspension compresses and rebounds.
#17 |
oh my ...
#18 | |
