01-17-2009, 10:49 AM | #1 |
Question on Brake Master Cylinder
I have a 1971 Chevy Super Cheyenne 4x4 I'm restoring. I have a couple of master cyl. One is a larger body with 2 reservoir the same. And the other has a larger up front and a smaller reservoir in back. Does anyone know which is correct.
01-17-2009, 05:39 PM | #2 |
Re: Question on Brake Master Cylinder
The one with the large & small resorvoir is for the disc brakes that you have.
01-17-2009, 06:06 PM | #3 |
Dave's not here, man
X2 I think the other one you have is for a drum/drum application.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
01-17-2009, 06:11 PM | #4 |
sharp as a marble
Not 100% sure, but I think that is the difference between a Moraine and a Bendix power booster. I know that you could get either on my 72 Blazer, and the master cylinders are different for each. ( I too have one of each ). If you go to NAPA's web site and look up a master cylinder for you truck, I think it will ask the question which booster do you have. They have pictures on their site to help you identify which booster you have.
01-17-2009, 06:28 PM | #5 |
If you have a Delco booster, your master cylinder should be the oval shaped one with both the same sized resevoirs.
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
01-18-2009, 04:52 PM | #6 |
So you guys are saying either could be OK. Thanks
01-18-2009, 05:30 PM | #7 |
member #16
Here is my delco mc.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
01-18-2009, 05:55 PM | #8 |
Old member
1971 Chevy with factory disc brakes. I just replaced this booster and the master cyclinder is one I replaced a few years ago. It is a direct replacement for the orignal one.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-18-2009, 06:41 PM | #9 |
Easy way to tell which type brakes you have is if the booster is black it is bendix, if gold/cadmium plated it is a delco- delco also has delco-moraine stamped into the case. Either m/c will work on either booster. My 71 has delco booster with bendix master, and 72 has delco /delco combo. If you have you original take it in- you will need it for a core anyway- and get the same configuration to go back with.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
