Old 03-04-2003, 06:58 PM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
My new lift and tires..
... I hope. If not go to the link in my signature.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-04-2003, 07:24 PM   #2
Mike C
Mike C's Avatar
Nice looking truck.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-04-2003, 09:04 PM   #3
Pont
I need another Barley Pop
Pont's Avatar
Looks good!
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 03-04-2003, 09:40 PM   #4
Mudder
Mudder's Avatar
Looks really good Jim.....
Mudder is offline   Reply With Quote
Old 03-05-2003, 01:12 PM   #5
Yukon Jack
Yukon Jack's Avatar
Looks good, what are the details on the lift and tire size?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-05-2003, 02:39 PM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Thanks everybody! In the front I have 2" HD Tuff country springs and ORD shackles. Shocks are skyjacker hydros. Also, replaced the pitman arm w/ a 2" drop. In the rear I added a TC leaf and 2" rugged trail block and u-bolts I had w/ an ORD u-bolt flip plate. Shocks are TC. My truck had an original 1" block that I discarded. I netted about 3" in the front and 3" in the back. Tires and wheels: 33" TSLs and 15"x10" U.S. Wheel wagon wheels. I bought these from Tyres International even with shipping they were cheaper than my local shops.
Old 03-06-2003, 08:08 AM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Another try at posting a picture..
.. I hope.
Old 03-07-2003, 03:17 AM   #8
ZOOMY
Nice
Looking good. I need to do that to my 71 GMC. Did you mail order the springs & pittman or get them locally.? What tranny & gears are you running. Mine has m465 with rockwell xfer case & 4:56's. I have a 205 xfer case for it & need higher gears for the highway. Do you know of anybody in your area with a stock black steering wheel for sale.?.........Zoomy
ZOOMY is offline   Reply With Quote
Old 03-07-2003, 04:18 AM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Mail ordered the springs/pitman arm from ORD. Tires/wheels came from Tyres Inernational. I have the SM465/NP205 combo w/ 4.10 gears. Real nice on the highway w/ the 33s. No steering wheels that I know of. My wife actually gave me a hard time about my small grant steering wheel told me it does not look right in the truck.
Old 03-07-2003, 10:47 AM   #10
Mike C
Mike C's Avatar
Get yourself a comfort grip wheel for a 69 Camaro. Use 67-68 woodgrain wheel install. You can get wheel with install as a set from Muscle Factory for $199. Here is a pic. Just looks right in these trucks:
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 03-09-2003, 11:46 AM   #11
jabarlow
Where did you get yhe u-bolt flip plate
72 Chevy K10 Short Stepside
72 gmc K2500
jabarlow is offline   Reply With Quote
Old 03-09-2003, 12:41 PM   #12
blazerboy72
looks good! i cant wait to get my lift and tires on.
blazerboy72 is offline   Reply With Quote
Old 03-09-2003, 05:40 PM   #13
racedvl
racedvl's Avatar
Looks great!!! Will look even better covered in MUD!!
racedvl is offline   Reply With Quote
Old 03-09-2003, 06:56 PM   #14
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
jabarlow, got it from www.offroaddesign.com they cost $25 for the pair I already had the u-bolts. Even though it's a 3/4 ton I had to use the 1/2 ton plates my dana 60 has 3" tubes while the 14 bolt has 3 and 3/8" tubes.
racedvl, soon very soon. I need to replace the inner axle seal on my front driver side, if the gear oil is getting out then water will get in. I'm getting my ducks in a row to replace the axle seals and add a locker. (waiting for my refund, per the status line should be before 4-1-03).
Old 03-10-2003, 02:29 AM   #15
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
nice droolllllllllll
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 03-11-2003, 12:36 AM   #16
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Looks good, I'm using the offroad design shackles on my blazer now and just ordred another set for my 68.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 03-11-2003, 11:18 AM   #17
Kruzer69
Kruzer69's Avatar
Very Good Looking Ride. Nice Work.
1969 Chev 4x4 9" of lift,327cid,38/16/16.5 Super Swampers,Factory Tack,Powder Coated Frame and other misc.
Calgary, Alberta, Canada
Kruzer69 is offline   Reply With Quote
