03-03-2003, 12:31 AM | #1 |
Semper Fidelis
steering box interchange?
Can I use later model power steering box on a 69-70 GMC K10 that doesn't have power steering now?
72 Chevy C 20 with 402 For sale 85 GMC K2500 83 Trans Am Cedar City, Utah (Missouri Native) |
03-03-2003, 01:50 AM | #2 |
I believe they are the same but you may run iinto problems with the rag joint splines. Some had different slpines and were different sized shafts.
03-04-2003, 12:01 AM | #3 |
Semper Fidelis
Thanks Mudder, would it work if I left on the rag joint from the later model box?
03-04-2003, 12:04 PM | #4 |
Any 73-87 PS box will bolt up. Just use the rag joint that comes with the box. Somewhere around 78 they have a smaller imput shaft (where rag joint goes).
Keith
GMC |
03-04-2003, 12:11 PM | #5 |
Also, sometime in the early 80's they switched from flare fittings to o-ring fittings on the hoses. You will have to get a matching pump or change the rear fitting to match the box. (Or have custom hoses made)
03-04-2003, 09:10 PM | #6 |
Semper Fidelis
