01-18-2009, 07:55 PM | #1 |
how to tell a 350 from a 400
so i found a truck that came from the factory with a 400, but i believe it may have a 350 in it, how do i tell if it is a 350 or 400? it has an edelbrock 1409 carb on it if that helps
01-18-2009, 09:01 PM | #2 |
Re: how to tell a 350 from a 400
i'm pretty sure a 400 has three freeze plugs on each side rather than the standard two that the other small blocks have.
01-18-2009, 09:02 PM | #3 |
I don't think that's ALWAYS true. Maybe someone else can chime in.
1986 Chevy 3/4 Ton 4X4 |
01-18-2009, 09:17 PM | #4 |
Workaholic
What leads you to believe it has a 350 in it???
1979 K-10 Silverado (work in progress) 1991 V1500 Subruban 1999 Suburban LT 4x4 2006 Suburban LTZ (daily driver) |
01-18-2009, 09:28 PM | #5 |
the valve covers? say performance 350 on them, but i thought they were interchangeable
01-18-2009, 09:34 PM | #6 |
Official Site Guitar Shredder
Harmonic Ballancer.....350 or any other small block for that matter OTHER than a 400 is internally balanced, a 400 is externally.. a 400 ballancer is not totally round someone correct me if i am wrong?..........But am pretty sure this is the way to I.D one from the other
01-18-2009, 10:02 PM | #7 |
Not all 400s had 3 plugs on each side. Best way is casting number off the back or the front pad on the front passanger side. Look at the ballancer. All but the 400 has a smooth outer ring, no indents. 400 has an area cut out of it for the external balance.
01-18-2009, 10:19 PM | #8 |
i dont really know engines so if anyone has pictures that would help a lot so i could go look
01-18-2009, 10:35 PM | #9 |
look on the front pass side on the block in front of the head.There is a pad there with numbers stamped into the block. Unless somebody machined the motor before. Give those numbers and that will help
01-19-2009, 02:40 AM | #10 |
This thread should answer your 400 smallblock ID questions.
http://67-72chevytrucks.com/vboard/s...80#post2789780 |
01-19-2009, 09:24 AM | #11 |
according to a book written by david Vizard, in the reference section under casting numbers. the 400 small block with four bolt mains, has a casting number of 3951511, had three freeze plugs and was manufactured from 70-73. the 400's with casting #'s 3951509 or 3030817 had two bolt mains, two freeze plugs and were manufactured between 74-76. you will find the casting number on the block behind the drivers side head.
01-19-2009, 11:17 AM | #12 |
Some 2 bolts have 3 plugs on the side. The one in my 'burb does and its a 4 bolt. Plus I just finished putting 4 bolt caps on a 2 bolt block that also has 3 plugs.
01-19-2009, 03:15 PM | #13 |
well i know what to look for but not where
where would i look for the harmonic balancer where would look for the casting number and this is in a fully put together complete truck, so if these are hidden behind something bolted on i wont be able to get t o them |
01-19-2009, 04:31 PM | #14 | |
Here's another pic of the 400 balancer and a 1980 509 engine. Last edited by Dooley; 01-20-2009 at 01:37 AM. |
01-19-2009, 07:58 PM | #15 |
yeah and im 90% sure its a 350, i guess i did look in the right place there were 4 pullies and they all looked round and normal
01-19-2009, 08:22 PM | #16 |
Weekend Warrior
Anyway you can post a picture of your balancer? The Pulley's have nothing to do with it.
The best picture would be if you could jack the truck up and take the picture from underneath looking forward at the balancer - if there is a cutout like the one pictured above than it is a 400 (The cutout part of the balancer is facing the rear of the engine)
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered Last edited by arkracing; 01-19-2009 at 08:24 PM. |
01-19-2009, 08:56 PM | #17 |
If you can crawl under the truck and look at the sides of the block, it'll tell. The 2 or 3 freeze plugs indicator doesn't work - I have a 509 casting block on the stand in my garage and it has only 2 freeze plugs, not even a boss for the third. Look at the sides of the block - if they're perfectly flat, it's a 305 or 350. If it's a 400, there will be small bulges around each cylinder, between 1/8" and 1/4" tall. Chevy only made 3 different casting numbers of 400 blocks - it'll have to end in 817, 509 or 511. The balancer is generally a good way to tell, but I use balancers with the counterweight on the inside, makes 'em look just like a 350 balancer. With this 2-freeze plug block and a balancer like I described, most casual observers will be sure it's a 350. I'm sure as hell not gonna set 'em straight.
