Old 01-05-2009, 11:46 AM   #1
Rokcrln
Rokcrln's Avatar
PT cruiser door handle swap need info
Does anyone recall seeing any write up's on ghetocrewzer's door handle swap? Do you know if he was able to make the stock Burb latches work with the PT cruiser handles or if he had to swap them out for other?
Thanks for any info you mifht have on this.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-05-2009, 12:30 PM   #2
ebfabman
Re: PT cruiser door handle swap need info
Not really a write up but Ive done this a few times on truck doors, its a fairly easy swap. Here are some comparo pics. Hope this helps.......eb
ebfabman is offline   Reply With Quote
Old 01-05-2009, 12:34 PM   #3
ebfabman
another
Old 01-05-2009, 12:48 PM   #4
lks dcvn
lks dcvn's Avatar
have any installed pix?
lks dcvn is offline   Reply With Quote
Old 01-05-2009, 12:50 PM   #5
Rokcrln
Rokcrln's Avatar
EB~ Very nice, so does the PT handle contact the stock Burb latch or are changes needed? If I am looking at it right you just bolt the front hole in, fill a small area at the front of the rear handle, drill one hole for the rear mount and you are done!
Kevin
LFD Inc.
Old 01-05-2009, 04:07 PM   #6
Hart_Rod
Hart_Rod's Avatar
I'm digging it, . How much per handle?
Hart_Rod is offline   Reply With Quote
Old 01-05-2009, 04:33 PM   #7
Rokcrln
Rokcrln's Avatar
$50 ea used or $79 new from the dealer. Different part number for front or rear so I need to find out why. They look the same but who knows. I need 5
Kevin
LFD Inc.
Old 01-05-2009, 06:27 PM   #8
ebfabman
Kevin, thats pretty much it. Its been a few years since I did the last one and only on trucks, no burds yet. I'll have to look around for installed pics. The ones I have here are for my daily driver to be done some time in the future, when ever that is
Old 01-05-2009, 09:21 PM   #9
Rokcrln
Rokcrln's Avatar
EB~ Thanks for the info. I picked up a set of 4 today (now I just need one more right side handle) so I will do a small how-to in the next day or so.
Ended up getting a set (4) for $150.
Kevin
LFD Inc.
Old 01-06-2009, 01:09 AM   #10
Rokcrln
Rokcrln's Avatar
Here are just a few quick pics and info.
The handles will work well. They need to be moved forward about 1/2" to get them centered in the finger niche and also to get the rear nut on the stud. The next thing to deal with is they sit up hill just a bit and are not tight to the curve. So I am going to look into doing a slight notch in the lower section of the door for just the button part of the handle to sit in, about a 1/4" or so. The pic with the small notch was just to get it in place for testing. Also the inner latch will need a small mod but will be real easy from the looks of it. I will play with it on Tuesday and see what I come up with.
Kevin
LFD Inc.
Old 01-07-2009, 08:45 AM   #11
Rokcrln
Rokcrln's Avatar
Well this idea is out the window. I mocked it up last night and in keeping the handle tight to the body they are just tilted up hill way to much to look right. In making them more flat they are sticking to far out from the body and they just look to much like an add on. I was hopping for a subtle look but it just did not happen. You can see all the mock up pick over in the LFD's 4 dr Tahoe build in the projects section.
Thanks for the help on this, maybe next time!
Kevin
LFD Inc.
Old 01-07-2009, 09:35 AM   #12
nightmare
nightmare's Avatar
Kevin, just out of curiosity, would this be to difficult to make work?
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 01-07-2009, 05:32 PM   #13
Rokcrln
Rokcrln's Avatar
With out having one in hand it is hard to say. Does it have a plunger that pushes striate out when you grip the handle Lille ours do now. If so than it would not be to bad to do.
Kevin
LFD Inc.
Old 01-07-2009, 07:32 PM   #14
ebfabman
Kevin, the uphill tilt has been an undesirable look the pt cruiser handles. Sounds like you are scraping the idea. Everyone has their preference but I really like the pt handles. Why not try the opposite of your little stand and recess the bottom area of the handle area and see if maybe it looks better. If I have a few minutes tomorrow I'll mock one up and post a few pics
Old 01-07-2009, 09:53 PM   #15
Rokcrln
Rokcrln's Avatar
I thought about that as well but the amount that they would have to go in ( = to what I cane out almost) puts the handle real close to the body. So when you put your fingers in to grab the handle they hit both at the same time if you know what I mean. Now you could always take the pocket section out of a 60-66 and use that for the mounting area. The body roll is almost a dead ringer for the 67-72's.
Kevin
LFD Inc.
And the PT handle is almost the same size as the 60-66
Old 01-08-2009, 09:19 AM   #16
nightmare
nightmare's Avatar
Kevin
LFD Inc.
It looks like it does, but I don't know for sure. I don't have one either. I was just doing a search to see if I could help find something that may work. It's from an 85-92 Jetta. Here is the link where I found them at: https://www.am-autoparts.com/AM/Exte...-/AM-86250252/
Mike
67-72 FAQ
Old 01-08-2009, 06:24 PM   #17
ebfabman
I'll put a pic here too.....
Old 01-08-2009, 07:06 PM   #18
Rokcrln
Rokcrln's Avatar
That looks very nice. I like the attention to detail you did with the lower inset along the entire bottom edge. Care to give any tips on how you did such a nice job? Also is the latch hooked up now? I would guess to say that by setting it in like you did the button is almost in just the right spot to actuate the latch.
Again nice work as usual.
Kevin
LFD Inc.
Old 01-12-2009, 12:37 PM   #19
jkaylor68gmc
jkaylor68gmc's Avatar
That is so cool.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 01-19-2009, 10:38 PM   #20
silvereagle07
silvereagle07's Avatar
The handles and pocket fit the door very nicely. Nice work.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
