Old 01-19-2009, 12:39 AM   #1
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Battery Relocation
Okay so how many of you have cleaned up the appearance of your engine bay? And one of those things on that list would be the battery and where to relocate it right? Well I know there where some older trucks with the battery moved to the frame rail under the cab with an access panel out out and hinged in right?
Seems to be a very limited amount of place we can tuck it out of the way but still have access to some kind of terminals under the hood if need be. So what would be a good spot that would be practical and functional at the same time?
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 01-19-2009, 01:14 AM   #2
sick69
sick69's Avatar
Re: Battery Relocation
A couple of things come to mind,,,
The obvious move it to the bed
Or if your running a gelcell(optima style) you could lay it on it's side and attach a shelf to the frame with a second set of cables to jumper terminals under the hood. All you would see under the hood is two copper terminals. The battery would be accessable via the hinged lid in the battery box on the shelf.
Some of the older (really old) vehicles had the battery in the cab,,,,again an optima style would be best but still not a great idea
Or build custom inner fenders to hide everything except the engine. Move everything lower in the engine compartment,,,,as close to the frame as possible.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 01-19-2009, 08:30 AM   #3
big_al_71
big_al_71's Avatar
I did not move my battery however I put it in facing the other way and ran the cables straight down to the frame where they are hardly noticeable. The engine bay in my truck is really clean no wires anywhere and the battery does not seem odd, just my .02...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-19-2009, 08:55 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
They also make chrome or stainless covers for them. I think board member Lippyp used one on his.
LockDoc
Leon
Old 01-20-2009, 08:35 AM   #5
C20-67_N_MO
Great ideas.
Thank you for your suggestions.
Old 01-20-2009, 09:02 AM   #6
jb4short
Damn Yankee
jb4short's Avatar
I plan on building a mount on the frame rail under the front of the bed on the passenger's side...then run the wires up the inside on the frame rail. Hopefully I haven't overlooked something major
jb4short is offline   Reply With Quote
