Old 01-06-2009, 07:38 AM   #1
LILRED66
LILRED66's Avatar
Doing a few items on LILRED66
I have my '66 Chevy C10 (LILRED66) at my shop at my house, doing a few miscellaneous things. Not much to show for, but I have been chasing an electrical gremlin and dealing with a pinhole leak in my factory Harrison 4-core Desert Cooler radiator. As with most of my projects, they start with a "short-list" of a few items and before I know it, I have a full page of "things to do".
In any case, I am having the radiator dipped, to clean up the build-up and leak tested/repaired, as needed. I am also repairing a few cracks in the original V8 radiator shroud.
I decided to replace the horn relay, voltage regulator and condenser, to make sure everything is up to snuff. I had already replaced all the wiring harnesses during the initial assembly about 5 years ago. The battery was bad, but luckily still under warranty, so I am putting in a new battery...the alternator checked out OK, so it is going back in. I also decided to do the headlight relay upgrade on the head lights, while I had it apart.
While I am at it, I decided to install a factory battery box, since the old one was not correct. These items, along with replacing several mismatched fasteners and the tailgate chain assemblies, I should have enough to keep me busy for a few hours.
LILRED66 is offline   Reply With Quote
Old 01-06-2009, 08:14 AM   #2
hewlett2002000
hewlett2002000's Avatar
Re: Doing a few items on LILRED66
nice. im curious if the relay upgrade really helps. just out of curiosity, did you get a little frustrated with the radiator hose? lol
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 01-06-2009, 08:44 AM   #3
LILRED66
LILRED66's Avatar
Good eye...actually, I am installing the factory "hard pipe" arrangement with the short hose pieces at each end, like the one pictured below. I just haven't installed the hard pipe or radiator yet.
Old 01-06-2009, 09:21 AM   #4
joe231
joe231's Avatar
nice Tony!
is that a factory washer fluid bottle and mount?
you have anymore of those?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-06-2009, 09:29 AM   #5
LILRED66
LILRED66's Avatar
joe231:
It is a factory washer bottle and mounting bracket. I need to check my inventory to see if I have an extra factory bottle and mounting bracket.
Old 01-06-2009, 10:07 AM   #6
YOLO
Custom Truck Lover!
YOLO's Avatar
nice. keep it up!
YOLO is offline   Reply With Quote
Old 01-06-2009, 10:55 AM   #7
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Nice work...by chance would you have one of those top radiator pipes ??
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 01-06-2009, 11:26 AM   #8
joe231
joe231's Avatar
thanks Tony!
CHEVY ONLY
Old 01-06-2009, 08:21 PM   #9
ol Curt
Junior Member
ol Curt's Avatar
Originally Posted by joe231 View Post
nice Tony!
I have found those out of a 67-69 Camaro fit perfectly as well. Shouldn't be a hard to find item.
ol Curt is offline   Reply With Quote
Old 01-07-2009, 01:21 AM   #10
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I was wandering about the upper hose as well. Now I understand. Looking great.
Alan's Classic is offline   Reply With Quote
Old 01-07-2009, 01:34 AM   #11
Jerry Jones
Happy Camper
Jerry Jones's Avatar
That is a neat looking rig, keep it up!
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
Old 01-07-2009, 10:45 AM   #12
protrash64
Resistance is Futile
protrash64's Avatar
I hate mismatched fastners!!!!.....I have spent so much time and many trips to the hardware store to get stuff and make everything uniform. Nothing like taking stuff apart and it requires 1/2 the tool box.
Hewlett kills me: took a second to see that.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-07-2009, 10:58 AM   #13
LILRED66
LILRED66's Avatar
I picked up this project about 5 years ago, in parts, from a fellow that had a change of heart. The photos are a little deceiving because the bed, cab and front clip were sit on the rolling chassis and loosely secured. The interior, engine bay, bed and plumbing were non-existent, so there was a lot of stuff involed, in putting it back together and getting it road-worthy.
In the process, I used the hardware, clips and fasteners I had available at the time. I have since acquired all the factory-style fasteners, clips and hardware, so when I pulled the radiator for repairs, I decided to replace those items with the factory-correct type.
Although this truck is not "Number One" restoration, I wanted to have it as factory-correct as possible, with the parts/pieces I have available in my inventory. Plus, that beats needing to go to the hardware store and FLAPS several times during the process.
Old 01-20-2009, 11:46 PM   #14
joe231
joe231's Avatar
CHEVY ONLY
Old 01-21-2009, 12:06 AM   #15
Alan's Classic
How's it coming?
Old 01-21-2009, 12:16 AM   #16
LILRED66
LILRED66's Avatar
I found a new reproduction radiator with the correct top & bottom tanks, although it is a three core instead of a four core. I found it at O'Reillys for about $200.00, plus tax. I check with many of the aftermarket truck parts suppliers and they were either way off or too expensive. I also checked several source online and they were about the same price as the unit I found at O'Reillys, so I figured I would go with it, since I could see it before I bought it. It was a direct bolt-in and appears to cool the truck properly.
I also did the headlight relay upgrade and that seemed to eliminate the electrical gremlin I was chasing. The headlights no longer flicker off and on. I need to do the final make-up of the plug at the radiator support, because the factory headlight harness at the radiator support is a two prong and the headlight relay plug is a three prong plug.
I will take a few photos and post them, however they are not much to look at, since they are just the engine bay put back together.
Thanks for checking in.
