Old 01-23-2009, 12:36 PM   #1
davidh
davidh's Avatar
Oil for oil bath air cleaner??
what oil do you put in these air filters? Not sure if I'll reuse. Seems like they run better with the paper insert vs. oil. comments suggestions? Can I put a paper element inside the oil bath cleaner?
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing.
davidh is offline   Reply With Quote
Old 01-23-2009, 06:30 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Oil for oil bath air cleaner??
just any motor oil will work.
not sure if there is a paper element conversion... but you could definatly gut the innards, and install one of those little paper ones, If you wanted to retain the look.
Imo there is nothing wrong with a stock oil bath air cleaner, they used them for years on cars, I think they ended up being replaced because the paper is cheaper , lower profile, and less messy to deal with.
