Old 01-22-2009, 08:39 PM   #1
HELLRAZR68
HELLRAZR68's Avatar
wheel hop like crazy
any goiod ideas on how to get rid of wheel hop every time i get on it in my truck, the rear end jumps around like crazy. any ideas guys. its a leaf spring and to the guys that help me with the bags ?. im not going to bag after all, just lower it more. thanks
HELLRAZR68 is offline   Reply With Quote
Old 01-22-2009, 08:46 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: wheel hop like crazy
The light rearend with leaf springs is a tough one on wheel hop. What kind of shocks are you running? If it were me, I would look into doing a Cal Tracs addition to my suspension.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-22-2009, 09:09 PM   #3
Wild83C10
Wild83C10's Avatar
You need to prevent the springs from wrapping up. You can either buy some bolt in caltrac bars or put in an extra shock on the rear like the Dodge SRT-10s have. Caltracs would be the best option as they will imrpove traction significantly.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 01-22-2009, 09:14 PM   #4
HELLRAZR68
HELLRAZR68's Avatar
do you guys have a link for the caltrac, im also thinking about when i redo the bed instead of doing the wood again do metal
Old 01-22-2009, 09:20 PM   #5
Wild83C10
Wild83C10's Avatar
http://calvertracing.com/
turbo=
Old 01-22-2009, 09:42 PM   #6
HELLRAZR68
HELLRAZR68's Avatar
thanks, do you guys know if they are hard to dial in or can i just slap them on and drive.
Old 01-22-2009, 10:34 PM   #7
vin63
vin63's Avatar
You can install them and drive, or you can spend the time to really dial them in with very incremental adjustments for racing...there are a few 8 second Novas in my area that run the Cal Tracs. I also have a friend who makes his own that is less expensive. I can contact him to see if he has the specs for your year truck.
Old 01-23-2009, 12:02 AM   #8
HELLRAZR68
HELLRAZR68's Avatar
that sound good bro thanks
Old 01-23-2009, 03:38 PM   #9
Ackattack
Ackattack's Avatar
I was racing my GMC (leaf spring) and I got axle wrap enough that I completely sheared off one of the caps on a U-joint.
If you want to lower it, I would just swap over to a trailing arm suspension. You should be able to find the arms/brackets in the salvage yard pretty easily (in good condition in California!). Bags are easy to install with trailing arms.
Ackattack is offline   Reply With Quote
Old 01-23-2009, 06:02 PM   #10
HELLRAZR68
HELLRAZR68's Avatar
no i think im just going to lower it, no more bags
Old 01-23-2009, 10:49 PM   #11
Wild83C10
Wild83C10's Avatar
If you lower it and do a flip kit in the rear you should buy new spring perches and weld them onto the underside of the axle. Otherwise you could possibly rip the perches off if you use the brackets they give you. I did this when I actually hooked up at the track. I put a dent in my driveshaft and screwed up one of the u-joint.
turbo=
