Old 01-25-2009, 10:17 AM   #1
KEL
72 GMC
KEL's Avatar
Vacuum advance question
Hey
How can I tell if my vacuum advance is working BEFORE I put the distributor back in the truck ? I hooked it up to another vehicle, but I don't know how much vacuum I need to pull before this thing should move. Any help would be appreciated.
Thanks guys.
KEL is offline   Reply With Quote
Old 01-25-2009, 10:28 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Vacuum advance question
If you're referring to the movement created by vacuum, it should move by just sucking on the end with your mouth. I use a short piece of hose if it's still on the engine.. Doesn't take a log of vacuum to move it.
If it doesn't move then it's defective.
68gmsee is offline   Reply With Quote
Old 01-25-2009, 10:34 AM   #3
KEL
72 GMC
KEL's Avatar
it doesn't move.
glad i asked before re-assembly
thanks for the help
