Old 01-25-2009, 05:46 PM   #1
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 4 valve system
OK,... say you do install check valves in-line to the bags. You hit the fill button. Air goes to the bags. Air will not transfer because of the check valve. Now,... how do you let the air out? The check valve keeps the air from transfering back out of the bag.
4 fills.
4 dumps.
Why not make your truck enjoyable to drive.
I'd leave it static before I'd run 4 valves.
Keith
Convert to disc brakes.
Old 01-25-2009, 06:34 PM   #2
redsled04
redsled04's Avatar
Re: 4 valve system
I never said I had check valves.Just 2 valves for the rear and two valves for the front.
I enjoyed it for about 50,000 miles this way.Most the time about an inch off the ground.
redsled04 is offline   Reply With Quote
