Old 01-27-2009, 02:58 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Panel repair?
I tried posting this in the paint and body section but didn't get any responses. The PO had a plastic bedliner in the truck and it has some bad spots in it, mainly on the front inside of the bed. My plans call for Line-x or Rhino Lining the bed, would a rust converter like eastwood sales be good enough to prevent it from rusting more? I can't see any holes where it has rust through. Or do I find a good replacement and put it in? What else holds on the front panel other than the bolts you can see? Here is a pic of the worst spot in the bed:
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 01-27-2009, 03:56 PM   #2
James McClure
One shot, one kill.
Re: Panel repair?
Best thing to do is remove panel and use POR or Zero rust on it following instructions on the cans, then hang the panel loose, spray it with bedliner and while the bedliner is still wet, tighten her up good. Never rust again. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
