Old 01-27-2009, 12:27 AM   #1
Imacarguytoo
Driverside Alternator
Does anyone have a pic of how the alternator mounts on the driverside with exhaust manifolds? Thanks!!
'67 C20 Lwb 350 4-Speed
'01 Chrysler Concorde LXI (wifes ride)
'91 Gmc Suburban 3/4 2wd 454 Tbi
'51 Jeep Cj3a "Willys" 350 V8
Imacarguytoo is offline   Reply With Quote
Old 01-27-2009, 05:46 AM   #2
JimKshortstep4x4
Re: Driverside Alternator
Do you have the older style exhaust manifold with the tapped holes on the front?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-27-2009, 08:44 AM   #3
Imacarguytoo
This is the way the genny mounts. I want to put a alternator on. I was told brackets from a 69-70 chevy pu will work. I got another toy to mess with when i get burnt out on the 67.
Old 01-27-2009, 09:46 AM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
hey carguy,
here's a pic of the brackets you need....you can use the 2 bolts right under that valve cover to bolt these up....disregard that bracket at the bottom of the pic
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-27-2009, 07:58 PM   #5
Imacarguytoo
Wanna sell them?
Old 01-27-2009, 08:03 PM   #6
mr48chev
mr48chev's Avatar
I think you should be able to use the bracket you have and use a long bolt clear through both ends of the bracket for the alternator to mount on with a spacer (piece of correct size pipe or tubing cut to length) behind the alternator. I did this on a 235 and think it should work with that bracket.
Old 01-27-2009, 10:50 PM   #7
gcburdic
Restoration Virgin!
gcburdic's Avatar
if Mr48chev's suggestion doesn't work for you...I have a set for sale here...http://67-72chevytrucks.com/vboard/s...d.php?t=296740
reply to the thread per board rules...Thanks
Geoff with a G
