Old 01-27-2009, 08:08 PM   #1
greygoose
greygoose's Avatar
Loose trans shifting
My truck has a three speed on the floor in it,that use to be on the column.Does a column shift trans shift different from a factory floor shift.Because when I shift it ,it's like I have to feel for the gears,they are not tight going between the gears.Is there something I can do about this,like a good linkage kit and if so which one or a link to get one.Or is it just how the trans shift, being that it was a column shift first. Thanks
If it ain't a chevy,I don't want it
greygoose is offline   Reply With Quote
Old 01-27-2009, 08:13 PM   #2
697498chevy
Re: Loose trans shifting
Put a Hurst ? floor shifter in my truck many years ago when column shifter got hopelessly fouled . Haven't had any problems . Wish the stick was a bit longer at times .
697498chevy is offline   Reply With Quote
