Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-26-2009, 02:00 PM   #1
BruthaMan
US Army Veteran
BruthaMan's Avatar
Help me pick out a set of heads for 383 Stroker
My 350 block and heads are at the machine shop. Block is getting a 383 stroker kit installed. Heads looked good, but figured I'd get a valve job while they were off. Never hurts.
Machinist just called back and said one of the heads was cracked. These were 76cc heads, which would have kept the compression ratio lower for pump gas.
So, I've never bought after market heads. I've heard of the brands...brodix, patriot, etc. I'm not an engine guy. This is the first motor I've ever had built.
Here are some things I can share, though not sure if all are needed:
1) Block is 4bolt main from an 86 Truck
2) 383 Stroker kit being installed
3) Cam is Comp Cams XE268 Kit here
4) Using COMP Cams Ultra Gold Aluminum Rocker Arms here
5) Using Edelbrock Performer Air-Gap Intake Manifold
6) Using Edelbrock 1406 600 CFM Carb
Uses: Daily driver, at best. I work at home, so it will probably be driven a few times per week. I don't plan on, nor have a desire, to go to the drag races. I want the torque, and I want a little "fun power" to get me in or out of trouble quick. I don't street race. I'm too old and value my insurance rates, plus people get killed.
My ultimate goal is reliability, smooth to fairly smooth idle. I do want to keep compression low for pump gas.
So what do I need, guys? I appreciate your advice and experiences.
BruthaMan is offline   Reply With Quote
Old 01-26-2009, 06:06 PM   #2
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Re: Help me pick out a set of heads for 383 Stroker
Any SR head should work. Might also do well with Vortecs.
WP SR Torquers
RHS Pro Torker
GM Vortecs
Sounds like a reasonable engine plan-
-Todd
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 01-28-2009, 03:04 PM   #3
BruthaMan
US Army Veteran
BruthaMan's Avatar
Thanks Todd.
I called RHS and gave them the specs on the motor, what I'm using, what I wanted, etc, and they are building a custom set of aluminum heads for me.
I appreciate the advice!
Old 01-28-2009, 05:08 PM   #4
djracer
djracer's Avatar
how expensive? The fast burns I listed are a deal.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
