Lokar Auto Shifter & switch to trade
Here's a Lokar shifter linkage part #ACA-1800 & a Lokar backup/neutral safety switch part #BL-1400U. These parts where on my 70 and are setup for a sbc with 350 turbo trans setting in the V8 place on the frame. I only have around 200 miles on the shifter linkage & have never wired up the switch. The switch was just mounted on the transmission pan. All parts look like new except where nuts have made contact with washers & shifter arm.
Keep in mine that the switch can only be used for either backup lights, or neutral safety switch. You can't do both at the same time. I have a copy of the installation instructions for the shifter linkage, but not the switch. Easy though. All you do is 2 bolts to the pan & the switch lever makes contact with the shifter lever at the trans. I'm looking for a trade first before I sell these. I'm looking for a Holley 600 cfm, list #1850, "Base Plate" with "Vacuum Secondary, or equivalent, (no Double Pumper plate) & 2 bare, dual line float bowls, (center float). Plate must be in nice shape & without excessive shaft play or modifications. Please respond to thread....
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 01-28-2009 at 07:46 AM. |
Re: Lokar Auto Shifter & switch to trade
ttt
1997 GMC Sierra Ext 1965 Mustang |
member
I would be interested in the switch if you decide to sell. Thanks!
John
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
If I do sell, will only sell as a set.
Out of the carpool lane.
I want first crack at it if you can't find a trade...
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
I have that same shifter on my 86 w/ a 4l80e
![]() Nice piece.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
ttt
