4l60e transmission/ shifter
I have a 6.0 lsx engine with a 4l60e transmission in a 71 manual truck. Right now it has a hurst floor shifter but I would love to move it to the steering colum to free up the floor space and look more original. Thanks for any sugestions.
Re: 4l60e transmission/ shifter
JUst out of curiosity, which floor shifter do you have [model number/name]? I am swapping in a 4L60E at some point and want it to be floor shifted.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
My burb was also an original 4 speed. I bought an auto column out of a 72' and bolted it in. Looks perfectly original. I run a straight rod down to the shift arm on the tranny, but you can also use the cable set-up. Is that the kind of info you're looking for?
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. |
as long as we're suggesting things for YOUR truck, I'd like to suggest a retrotec or a shrifter... and make it look decent with a classic steering wheel.
PADDLE SHIFT FTMFW!
RN U OVR |
#5 | |
David |
#6 | |
Thanks David...that's pretty close to what I had in mind.
Not to hijack your thread. Just another question concerning the swap. How do you get around the detent for the OD. With the standard 3 speed auto column.
68 C10 2WD 250 6cyl Clifford 4bl, Edl Carb, Headers, work in progress |
Too Dumb To Know Better
I use the standard PRND21 and it works fine. D is Drive and the other 3 actually don't line up, but I don't mind. I have the regular tilt column from a 72 along with the factory linkage and a 4L60E.
dear sirs,
retrotek: ![]() shrifter: ![]()
RN U OVR |
![]() Join Date: Nov 2008
hhhmm cool idea where do i get one of these paddle shifters?? i have an 700r4 and was going to go with a manual column to avoid the frustrations of rebuilding my auto tilt column. are these shifters expensive?
![]() Join Date: Oct 2005
Find an auto column, get a Lokar universal trans linkage, and then get an overdrive indicator lense from truckandcarshop.com (I'm sure other vendors have it as well).
Works perfect.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
