Old 01-29-2009, 11:26 AM   #1
dan42
dan42's Avatar
picture of cowl screen -
Does anyone have a picture of how you installed the screen for catching leaves under the cowl from the backside? Did you silicone it there, or just lay it there and tighten the screws up against it? Any pictures would be very helpful - thanks.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 01-29-2009, 11:34 AM   #2
nightmare
nightmare's Avatar
Re: picture of cowl screen -
I got mine from LMC. It had tabs on there that sandwiched between the cowl and the cab. I wanted something that was quick and painless. Sorry, I don't have any pics of this.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 01-29-2009, 11:58 AM   #3
Sinister
Between Trucks...
Sinister's Avatar
I got mine from LMC as well. Got lazy and didn't want to rig something up.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 01-29-2009, 12:54 PM   #4
leddzepp
Moderator
leddzepp's Avatar
It comes in two pieces. Pretty self-explanatory, easy to install. Silicone is not necessary.
Old 01-29-2009, 01:01 PM   #5
69sixpackbee
I used plain 'ol aluminum screen for home windows. I cut it, formed it to the inside and put aluminum tape and 3M spray adhesive to hold it in place. Cheaper and very durable.
69sixpackbee is offline   Reply With Quote
Old 01-29-2009, 01:57 PM   #6
Brad
Out of the carpool lane.
Brad's Avatar
I too found some black fiberglass window screen that was 72" wide at the local hardware store and just epoxied it in place. Around here that's a better solution than the LMC screens due to all the pine needles and evergreen 'leaves'.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 01-29-2009, 06:14 PM   #7
68gmsee
Active Member
68gmsee's Avatar
I did mine from Gutter Guard screening from Lowes. I think I paid about $10.
It's flexible, durable and easy to cut to fit with scissors. I cut it so that it overlapped and just placed the cowl on top to hold it in place. Have enough left over for my 68 GMC and more.
I heard the only problem is if you have small pine needles around your area it may not keep them all out.
68gmsee is offline   Reply With Quote
Old 01-29-2009, 06:18 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I got SS ones from Tim Christian. I used plastic zip ties to
hold them in place until the screws went into the tabs
Then I just cut the zip ties after I bolted it all in place
Someone ask for pic's?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-29-2009, 06:37 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I did exactly the same as Luv2X's including using the same BB Vendor.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-29-2009, 08:17 PM   #10
mas09ts
mas09ts's Avatar
I ued that gutter stuff in the roll also . . .
Mitch
22yrs. Young
1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011
Current Project 68 Gmc "Second Chance"
Go to my 68 GMC Shorty Rebuild Thread
http://67-72chevytrucks.com/vboard/s...39#post6341739
mas09ts is offline   Reply With Quote
Old 01-29-2009, 08:20 PM   #11
dan42
dan42's Avatar
Perfect - that's what I was looking for. Stainless make a lot of sense, but I am going the cheapie route for now, with OSH screen, and I'll paint it black (my truck is black)
Philippians 4: 6-7
Old 01-29-2009, 09:47 PM   #12
texanidiot25
Eat My Rust
texanidiot25's Avatar
Just used some wire mesh. Keeps all the pine needles out. Those things get through everything.
texanidiot25 is offline   Reply With Quote
Old 02-03-2009, 01:19 PM   #13
Andy4639
Old member
Andy4639's Avatar
Well I finally found the pictures I took. I did the Lowes screen porch route. I had it left over from the back porch project.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
