Old 01-29-2009, 09:26 PM   #1
davidh
davidh's Avatar
can someone show me
where the id for the 6cy is? I hear its by the distributor. If you have a clean motor can you show it on here for me? I can easily tell the 292 but the 230/250 look similar.
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing.
davidh is offline   Reply With Quote
Old 01-29-2009, 09:59 PM   #2
502tripower
502tripower's Avatar
Re: can someone show me
There is a machined area by the distributor. You just need to clean it off a bit and you will be able to read it. Here is a list of suffix codes.
http://www.348-409.com/suffixsb.htm
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 01-29-2009, 11:01 PM   #3
davidh
davidh's Avatar
to the side? front of? back of?
Old 01-30-2009, 03:30 AM   #4
502tripower
You are going to have to look for a machined area at about the same area as the distributor mount hole. It is there you just need to look.
98' FXD
2002 2500HD
