Old 01-31-2009, 03:31 PM   #1
hilandr452
hilandr452's Avatar
V8 distributor
I assume all the 74-88 chevy OEM HEI disrtributors are the same between the big blocks and small blocks is that correct?
Dan Smith
Colorado Springs, CO
71 GMC Custom Camper "Longhorn" 454, TH400
73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny
"DON'T TREAD ON ME !!!"
My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442
hilandr452 is offline   Reply With Quote
Old 01-31-2009, 04:15 PM   #2
adpostel
New Member
Re: V8 distributor
To my knowledge, they are all the same....
1968 C10 LWB Project 454/400
http://www.cardomain.com/ride/2417713
adpostel is offline   Reply With Quote
Old 01-31-2009, 05:24 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: V8 distributor
it evolved quite a bit and was computer contrilled later on... meaning you can't just stab one in your early engine. however, big block and small block units were the same though.
Old 02-01-2009, 12:45 AM   #4
hilandr452
hilandr452's Avatar
Re: V8 distributor
Thanks LHM, adpostel I will try to find one in the junkyard. I took the one out of my 83 454 and installed it in my 71 402 a few months ago, now I'm trying to find one for my 454 so I can move it.
Dan
Dan Smith
Old 02-01-2009, 01:19 AM   #5
sinned4me
Re: V8 distributor
there are three different control modules- 4 pin, 5-pin, and 7-pin. then there are a bunch of different vac advances. O'reillys, or CSK both sell Accel or MSD ones pretty inexpensively. I have not tried changing from one module to the others but bb to sb works. Remember if you are running a roller cam to switch the drive gear to a bronze one.
sinned4me is offline   Reply With Quote
Old 02-01-2009, 01:29 AM   #6
sinned4me
Re: V8 distributor
new MSD street fire at www.oreillyautoparts.com number 8362 for $159.99
Old 02-01-2009, 11:22 AM   #7
Longhorn Man
Re: V8 distributor
look on e-bay... search skip white. $50 HEI units, complete with cap and rotor. Kinda hard to beat that number.
Old 02-01-2009, 11:28 AM   #8
Brock396
Re: V8 distributor
why do u need a bronze gear with a roller cam?
Brock396 is offline   Reply With Quote
Old 02-01-2009, 12:40 PM   #9
Bruce88
Bruce88's Avatar
Re: V8 distributor
The roller cam is made from different kind of material than a flat tappet cam. If I remember correctly the roller cam is a billet material and the flat tappet cam is cast material. If you use a stock distributor gear they can eat each other when running. I ran a bronze gear a number of years ago and it wears out very quickly, approximately 4000 miles it’s primarily used in racing engines. GM did develop a distributor gear that works with roller cams that does not wear out and is made for street use, I forget the part number but you should be able to get one from GM dealership parts. Also some aftermarket cam manufactures like Crain have been installing a cast gear on there roller cams so no need for a distributor gear change is required.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
