02-03-2009, 06:30 PM | #1 |
Project:1965 3/4 ton 4x4
73 running gear donor. Truck lived a hard life in Whitefish Montana plowing snow.
Front clip and cab donor. 1969 4x4 long bed frame 73-87 4" Rancho lift springs with 2" drop cross memeber Last edited by JTR; 02-07-2009 at 11:46 PM. |
02-03-2009, 06:36 PM | #2 |
Re: 65 3/4 ton 4x4 buildup
14 bolt got disk brakes
Front 44 gets new balljoints and full high steer. set motor/tranny/t-case 80's van tilt steering column, moded rear cab mount for 69 frame. 75 Surburban 3/4 ton 4x4 booster and master cylinder Last edited by JTR; 02-03-2009 at 06:38 PM. |
02-03-2009, 06:41 PM | #3 |
That's great.. I am looking at doing something very similar with a running gear from a 72 K20 and a 65 GMC body.... what exactly did you have to do with the body mounts to get the cab and clip to mount up correctly???? That is my biggest stumbling block as I plan this out... Thanks for the post!!!
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
02-03-2009, 07:04 PM | #4 |
Looks good! Can't wait to see more progress.
02-03-2009, 09:07 PM | #5 | |
I put the laughter n slaughter
I still dont care how you did it in California!!! Last edited by Wolfinthesnow; 02-03-2009 at 09:07 PM. |
02-03-2009, 10:09 PM | #6 |
1966 Crew Cab & 4X4 Fanatic
Hello JTR,
Welcome from Arizona. Your progress to this point looks great. What is up with the bed, it does not look right? What are your plans for your truck, the stock look or modified look? Also what are your plans for paint. Have you been over to the 4x4 Forum on this board and checked out the thread "Post Pics, Let's See How Many 60-66 4x4's Are Out There". If you haven't go on over and check it out, this will give you the inspiration to shift into high gear and get that project done. Keep us posted with your progress. |
02-03-2009, 10:12 PM | #7 |
Urban Chop Shop
Looking good.. I am glad to see a 4x4.. They were my first love growing up as a country boy.. Looks like its gonna be a killer ride.. Keep up the good work and the great pictures.
2003 Chevy Trailblazer LTZ, 2.5" Susp Lift, Tinted, HID's/LED interior/ Lot of upgrades and little mods 1965 Chevy 1/2T Longbox, soon to be a slammed shop truck Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=591266 Semper Fi Marines |
02-03-2009, 10:34 PM | #8 | ||
69 on 65 frame = drill new hole for bolt in original mount. Quote:
Plans for paint are Black Polyurethane Aircraft paint. A friend of mine can hook me up with some for a case of beer. How can I pass that up? This rig is actually for my wife, she likes Chevy shortbox's and I had some parts laying around. This is my first Chevy build so I am having fun learning something new. Thanks for the excellent info on this site! |
02-03-2009, 10:43 PM | #9 |
Went to the junkyard this weekend to pick up the fuel injection parts for this thing. Came home with some other stuff too.
Total was $200 2wd GM box with Ford Van Pitman arm. Arm was included in the price listed above. ECU TBI dizzy and coil |
02-03-2009, 11:06 PM | #10 |
Nice work!!
looks like it is coming together nicely!!! couple questions about the column......do you know exactly what year van, and does it have the ignition on it?
CHEVY ONLY |
02-03-2009, 11:11 PM | #11 |
Hey Y'all!!
Neat build you have going on there. Keep us posted!
Just hopin' I live long enough to finish something!!! |
02-03-2009, 11:53 PM | #12 |
Sorry, don't know exactly it was in the back of one of the trucks we parted out. It has the flat connector on it like the mid to late 70's GM and some Full Size Jeep columns. It does not have ignition on it but it did have the cruise wiring.
02-04-2009, 01:52 AM | #13 |
60-66 Nut
Cool project Are you going to adapt the TB onto the Performer intake? Do I see a shackle flip in the rear? What TC are you running?
BTW Welcome to the board
02-04-2009, 09:33 AM | #14 |
TexasBowhunter
Allsome!
If I wouldnt have slid my cab back....the distributer would have never cleared the firewall. I like the bobbed bed!
Build in progress for son's first truck. |
02-04-2009, 10:32 AM | #15 | |
T-case is NP-205. Last edited by JTR; 02-04-2009 at 10:34 AM. Reason: tcase info |
02-04-2009, 10:58 AM | #16 |
cool, thanks for the info!
CHEVY ONLY |
02-04-2009, 11:17 AM | #17 |
TexasBowhunter
Thats how I did mine! Lowering shackles will raise it now.
02-04-2009, 11:20 AM | #18 |
TexasBowhunter
What length are your front springs?
02-04-2009, 12:41 PM | #19 |
02-07-2009, 09:52 AM | #20 | |
CHEVY ONLY |
02-07-2009, 10:48 PM | #21 |
Pics of column
Also ran into problems with my Van pitaman arm...couldn't get it to center correctly. This is why |
03-03-2009, 11:10 AM | #22 |
Few updates.....fixed holes in the floor pan, been sanding for days and days.
Sold...1965 Chevy 3x4 ton 4x4, short bed step side |
03-03-2009, 11:38 AM | #23 |
nice work!!!
looks like fun!! my wife is the designated grinder/sander/painter i just turn wrenches....
CHEVY ONLY |
03-03-2009, 12:29 PM | #24 |
Looks good! Its always nice to have help!
03-11-2009, 11:17 AM | #25 |
Got some used wheels
16x12 Welds on 305 GSRs Frame cut, took 12 inches out. Used a J20 Knuckle on the passenger side, had the same casting as the Chevy knuckle that came off it but the Camber is WAY off now. Ordered the spindle shim from NAPA today. We will see if I can get the cambeer close.
