screamin eagle
Re: cab shims
how would I cut down a bushing,its molded with 2 pieces of metal
SCREAMIN EAGLE |
Re: cab shims
I use large washers for shims.
I have tried to reduce the radiator support bushings but what I have found is that you almost have to go with no supports at the radiator in order to get the results equivalent to 1/4" shims under the body. I have not seen any problems from shimming under the body. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
screamin eagle
Re: cab shims
thanks for the replies-I have a extra bushing and I will cut that down and use it as a shim instead of the shims I have
SCREAMIN EAGLE |
