Old 03-07-2003, 12:35 AM   #1
ocbaud
Garage Queen Material
new gears?
i've been thinking, instead of frontend kit or new exhaust for my birthday, i could ask for a new gear kit for my rearend.
there is a richmond gear package in jegs for $304 that includes everything needed to install the new ring & pinion, new bolts for the cover, cover gasket, bearings, shims, seal, and oil.
i'm thinking replacing the 2.73's would help my gas milege quite a bit and also help my truck be a little quicker too!
i would be getting 3.73's and then an eaton posi later this summer, possibly
ocbaud is offline   Reply With Quote
Old 03-07-2003, 12:45 AM   #2
CHaingKaiShek
I love goooooold!
CHaingKaiShek's Avatar
Could be mistaken but I think the lower gear ratio (2.73) would be better for gas miliage but worse for takeoff at the line. The 3.73s would give a better take off, but have an adverse effect on gas miliage.
However, 3.73s are good all around gears. You should not notice too much of a change if you switch to them. However I hear it's quite a PITA job to do.
Jeff :p
"Musha ring dum a doo dum a da
Whack for my daddy-o
There's whiskey in the jar-o."
CHaingKaiShek is offline   Reply With Quote
Old 03-07-2003, 12:48 AM   #3
ocbaud
i say it would help with the gas because it would keep my in my powerband without having to have my foot on the pedal as much.
so its like this:
with the 2.73's to get the acceloration i want i would have to have the pedal 3/4's of the way in
with the 3.73's i would have to have the pedal 1/4 or the way in
so something to that affect
with the lower gears, i wouldnt have to use the accelorator as much since the gears would help a lot
Old 03-07-2003, 12:56 AM   #4
CHaingKaiShek
I love goooooold!
At the same time, it's going to require more throttle at higher RPM's to move the same amount of truck. :p
The engine would also be working harder (turning more RPM) to keep the truck at 60mph, than it would with the lower gear ratio. It's a double edged sword really, but hey. The changes should not be too bad. If you were going to 4.56's or something however.
Jeff
Old 03-07-2003, 12:58 AM   #5
ocbaud
i was thinking about something along the lines of 6.32's?
do you think that would be to low?
Old 03-07-2003, 01:03 AM   #6
CHaingKaiShek
I love goooooold!
Sounds good to me. But I'm not buying your fuel.
Jeff
Old 03-07-2003, 01:08 AM   #7
ocbaud
Jeff
what about my tires?
Old 03-07-2003, 01:08 AM   #8
BaggedC10
Under construction!
BaggedC10's Avatar
Wait to replace the gears once you get a real motor in there---A 350!
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 03-07-2003, 02:24 AM   #9
67_SS396
I hope you are also thinking about the cost of having someone (competent) to install your new gear set. It's not something that the average Joe can do. You have to have the proper tools to do it right. Typically it will run you $100-$200 for an install, atleast around here it does. I have a guy that will do my gears for a case of beer and teach me at the same time, but that's a different story. He owes me.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 03-07-2003, 03:14 AM   #10
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Eric- I would wait to get the posi and gears at the same time. You will need to get both setup by a professional like Ryan mentioned above. If you installed the gears then later did the posi you will be paying twice the labor. Plus another problem is that the carrier you have now may not work (probably won't) with the new gear setup. If it's like my rear axle it has a series 3 and the gears you are probably looking at are series 4. They have 3.73 that can fit the 3.73 but grab the series 4 and be much better off.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
