02-05-2009, 07:26 AM | #7 |
Re: Relocated Fuel Cell
it's behind the tire which is safer incase of a leak. Plus i didn't want it inside the bed because i didn't want to drill a hole for a shut off switch through my bed side or tailgate. The vaseline helps with making it easier to clean. I would think you could have more problems through tech with the battery in the stock location because of a leak being right infront of the front tire. But i never had a problem with either.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
