Old 02-05-2009, 12:55 PM   #1
mas09ts
mas09ts's Avatar
Lightbulb V8 in 6 cylinder position???
Is it ok to leave a v8 in the six cylinder position???
Any info appreciated. . .
Mitch
22yrs. Young
1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011
Current Project 68 Gmc "Second Chance"
Go to my 68 GMC Shorty Rebuild Thread
http://67-72chevytrucks.com/vboard/s...39#post6341739
mas09ts is offline   Reply With Quote
Old 02-05-2009, 01:06 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: V8 in 6 cylinder position???
I used mine like that for many years because I wasn't comfortable with how close the distributor was to the firewall. The only thing I noticed was a slight weight shift towards the front. Also, my drive shaft yoke was engaging the 350 transmission by only 1-1/2 inches.
On my next rebuild I'm thinking of moving the mounts back about 1 to 1-1/2 inch and redrilling the bolt holes. That will still give me plenty of clearance on dis and shift the weight more to the back.
68gmsee is offline   Reply With Quote
Old 02-05-2009, 01:19 PM   #3
mas09ts
mas09ts's Avatar
Well, mine is closer to the firewall see the pics below
Is it alright sitting like this??? I believe so what do you guys think??
Mitch
22yrs. Young
Old 02-05-2009, 01:23 PM   #4
You mean when the V8 is mounted back in the 6cyl position?Where the transmission is in the position for a 6cyl,right?.Yes,it`s ok.I don`t,I always set a V8 forward so it`s not all stuffed back into the firewall and sits the way the factory did.
Old 02-05-2009, 01:38 PM   #5
mas09ts
mas09ts's Avatar
But I shouldn't have any problems with it like this should I?
Mitch
22yrs. Young
Old 02-05-2009, 01:44 PM   #6
TDs6t9
TDs6t9's Avatar
The only thing I have noticed is in that position with a single core radiator is the truck seems to run a little warmer, if you don't have a fan shroud. Everything else on mine has been great.
TDs6t9 is offline   Reply With Quote
Old 02-05-2009, 02:14 PM   #7
caminokid
Chevy nut
caminokid's Avatar
So let me get this right...Its ok for the 8 to sit in the 6 position? I am getting ready to this swap. I have everything to do it...but dont want to rip everything apart.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 02-05-2009, 02:24 PM   #8
mas09ts
mas09ts's Avatar
So I probably need to get a fan shroud, I'll track one down.
Mitch
22yrs. Young
Old 02-05-2009, 03:00 PM   #9
MikeN
MikeN's Avatar
I've done the 230-I6 to 350-V8 swap on my 64 C10. My truck is a 3-speed manual, and I left both the engine mounts and the bellhousing side mounts in the original, I6 location. Works like a charm. Distributor is a little tight to the firewall, but no big deal.
MikeN is offline   Reply With Quote
Old 02-05-2009, 03:07 PM   #10
too much stuff
Roadtrip!
too much stuff's Avatar
You shouldn't have any problems other than being snug with the dist. I used a 4x4 fan shroud which fit nicely and ran fairly cool...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-05-2009, 04:17 PM   #11
Yeah,1/2 the swaps are done that way.
Old 02-05-2009, 05:20 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
that's where the small block goes on a 4X4... you'll be fine.
Old 02-05-2009, 05:24 PM   #13
bobbo
Droppin' It Like It's Hot!
bobbo's Avatar
My 283 is mounted in the 6 cyl position. A bit close on the dizzy but there is enough clearance. I have driven mine like this to TN, CO, Kansas City, and hundreds of miles in between with no problems. I installed an electric cooling fan so I don't have any issues with the shroud/fan. I also have the HEI dizzy which is a bit larger than the points or other ones. Have about 1/4" between the firewall and the cap. As long as your motor mounts are good, you shouldn't have any problems.
Robert
Life Member
RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09
1969 1500
Norwood, MO 2007
Big Sandy, TN 2008 Had nothing to do with the forklift!
Kirkwood, MO (Midwest Meet 2009)
Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014
SUPPORT THE SITE HERE!
bobbo is offline   Reply With Quote
Old 02-05-2009, 05:42 PM   #14
68gmsee
Active Member
68gmsee's Avatar
[QUOTE=68gmsee;3126708]I used mine like that for many years (and then moved it forward) because I wasn't comfortable with how close the distributor was to the firewall. The only thing I noticed was a slight weight shift towards the front....
QUOTE]
Sorry left words out. That's what happends when you get old and get distracted...
I mentioned the weight shift and drive shaft problem in case you decide to move it forward to give you more clearance. I had the original 6 cylinder front springs and someone mentioned to me that there was a difference between those and the V8 springs when they came out.
Old 02-05-2009, 05:47 PM   #15
caminokid
Chevy nut
caminokid's Avatar
Now i wonder if my headers are going to fit...and if my exhaust is going to fit off my old 69? I can put electric fans in.
Old 02-05-2009, 06:14 PM   #16
Blue71LWB
Blue71LWB's Avatar
Makes sense why the 4x4 shroud works better.(I learn something on here every day)
Working on my first 1,000 post.
I'm sure I'll get there before this project is over .
Blue71LWB is offline   Reply With Quote
Old 02-05-2009, 07:16 PM   #17
bigsnookmaster
bigsnookmaster's Avatar
It works better in the six cyl. position if you're racing. Better weight transfer.
bigsnookmaster is offline   Reply With Quote
Old 02-05-2009, 07:45 PM   #18
1969K10
1969K10's Avatar
I ran headers on my V8 in the I6 position. Had to run the Z-bar for the clutch thru the header, between 5 & 7. Ran like that for nearly 100K until some lady felt like shortening my '72 by pulling out in front of me...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 02-05-2009, 07:49 PM   #19
mas09ts
mas09ts's Avatar
Well thanks guys, I didnt think about moving the mounts when I done the v8 swap. I thought you could do it this way though. But thanks for everyting, I just wasnt sure if it would be alright.
Mitch
22yrs. Young
Old 02-05-2009, 08:53 PM   #20
john02fxdl
OK, since we're on the topic, I am also doing a I6 to V8 conversion and a 3spd manual to TH350 swap. Already took out mid-mount crossmember. I thought someone said on here to swap the I6 perches(left to right, right to left) and put them in the front holes. I tried that, doesn't line up. Do I have to bend the bottom of the perch to get it to line up with the holes on the crossmember? Since I'm doing a complete swap, I want the 350 in the front holes and I'll install the tranny crossmember where it lines up with the trans. Or just search the boneyard for V8 mounts already in front holes, that way I know I'll get the right ones. Sorry to bust in on your dilemma, just that I had a similar question and no sense posting a new thread for the same topic.
john02fxdl is offline   Reply With Quote
Old 02-05-2009, 09:02 PM   #21
mas09ts
mas09ts's Avatar
Hey thats alright john02fxdl, maybe this thread can help alot of people. My question has done been answered.
Mitch
22yrs. Young
