Cab mounting hardware dimensions
I am replacing my cab and support bushings. I purchased the energy suspension kit #3-4107 for 67-72, 4x4, polygraphite. It says to use several of the original bolts, sleeves. Mine are so rusted out that I only could find one that looked like a sleeve inside the bushings. So I need some dimensions or a vendor that would sell these.
For the forward cab support (position 2) - sleeve diameter, wall thickness and length For the rear cab support (position 3) mushroom shaped - top diameter and thickness, lower diameter and wall thickness. I figure I could make these out of stainless pipe and plate if I needed to. Thank you for any info that anyone has. Eric
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" |
![]() Join Date: Feb 2001
Re: Cab mounting hardware dimensions
I would check out LMC.
