Old 03-05-2003, 01:22 PM   #1
Reumster
L.E.D. Freak
Reumster's Avatar
Blazer experts/Tube coming up by gas tube in bed?
Can I remove it?? I want to eliminate it.
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 03-05-2003, 01:45 PM   #2
JimKshortstep4x4
Talking
I guess that I would not remove it. It is part of your vent/vapor recovery system and it is there to route vapors to your canister.
If you do decide to remove it, you will need to address the lines from the tank and canister, especially the tank because you may have a gasoline leak caused by the open lines.
jim
Old 03-05-2003, 02:22 PM   #3
tom hand
CCRider
tom hand's Avatar
If it's the tube I am thinking of, it is simply a vent tube for fillling up the tank. If you remove it it will take you forever to pump gas in the tank without the pump cutting off
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 03-05-2003, 02:34 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I agree with tom hand. Why would you want to remove it anyway?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 03-06-2003, 01:27 AM   #5
Reumster
L.E.D. Freak
Reumster's Avatar
When pumping gas the nozzle shuts off anyway if you stick it to far in. I don't have the charcoal canister on my blazer anyway. This is why I want to address the issue, I'm thinking it's effecting my gas milage. Do trucks have this? And if not what if all these guys are adding blazer tanks? Somethings got to give.
(406)675-8082
Old 03-06-2003, 12:10 PM   #6
Reumster
L.E.D. Freak
Reumster's Avatar
TTT
(406)675-8082
Old 03-06-2003, 02:22 PM   #7
tom hand
CCRider
tom hand's Avatar
I don't think it is effecting you gas mileage unless it is leaking gas on the ground, but I think if you remove it you'll be looking at some 30 minute fill-ups...if you don't think so remove it and plug it and see what happens
Olive Branch MS
Old 03-07-2003, 09:38 AM   #8
Andy4639
Old member
Andy4639's Avatar
Cool opitions
Reumster,
First off I don't know of anyway it can effect your fuel milage in less it's leaking quit a bit, and if thats the case I would have it fixed. Trucks do have the vent hose just not the tube, the gas tank in the trucks run a vent line up through the cab roof.
Now if you want to remove the tube, that could be done as long as you reroute the gas hose so that it will vent. The only problem with this is if it is below the tank it's going to fill up with gas sooner or later and start draining the tank. You may be able to put it inside the sheet metal cover that covers the filler tube up if you wanted hid.
I would suggest getting under the blazer and see where it goes and how it's hooked up to the tank, and go from there.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
