Old 02-02-2009, 04:24 PM   #1
au03z71
au03z71's Avatar
What else do I need?
I've got 4 bags, eight 3/8" SMC valves, tank, compressor, fittings, and switchbox coming for the 72. Other than line, mounting brackets for front, and c-notch, what else do I need? Drop spindles? New Panhard Bar? I saw something about a shock relocator kit, will I need this?
au03z71 is offline   Reply With Quote
Old 02-02-2009, 04:27 PM   #2
edflores
Re: What else do I need?
drop spindles for sure. wiring. 4 GA for the comp,
edflores is offline   Reply With Quote
Old 02-02-2009, 06:35 PM   #3
Kayotic
Kayotic's Avatar
4Ga For the compresor, Really?
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 02-02-2009, 08:50 PM   #4
au03z71
au03z71's Avatar
What about the shock relocator kit?
Old 02-02-2009, 10:00 PM   #5
edflores
sorry. i meant 8ga.
Old 02-02-2009, 11:18 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Yes,... shock relocators shorter shocks front and rear, and an adjustable track bar (panhard bar)
I suggest looking at Early Classic Enterprises (ECE) for all of the above items.
Keith
Convert to disc brakes.
Old 02-03-2009, 08:46 AM   #7
au03z71
au03z71's Avatar
Cool thanks for all the input.
Old 02-03-2009, 12:34 PM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
You're gonna want blocks too. Get your shocks at PepBoys and save some cash. Do the cheap blue Monroes- same thing ART uses without the cool sticker and inflated pricing...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-03-2009, 01:12 PM   #9
au03z71
au03z71's Avatar
Do you have the model of those shocks? Also, what size blocks?
Old 02-03-2009, 03:36 PM   #10
gringoloco
A guy with a truck
gringoloco's Avatar
You will want the 2" lowering blocks. This will give you a good ride height while still allowing for some decent pressure in the bags= better ride quality. It will also bury you in the notch when aired-out.
Shocks:
Front- Monroe 33033
Rear- Monroe 32301
The rear shock selection assumes you are using shock relocators and 2" blocks. Deviating from this recipe may cause the shocks to bottom out. Don't pay more than $20 each for them or you're getting ripped off...
-Chris
Old 02-03-2009, 05:24 PM   #11
VA72C10
VA72C10
VA72C10's Avatar
Most people use 2" drop blocks....there are several board members including ECE that sell them...just make sure you get the longer U-bolts with them. They basically allow you to ride with more air in the bags for a better ride.
Thanks for the part #s on the shocks I was lookign for those...
Old 02-03-2009, 07:40 PM   #12
texastrendz
ya need to start bolting stuff on, ha ha, just kiddin, good luck on the total install.
texastrendz is offline   Reply With Quote
Old 02-03-2009, 09:15 PM   #13
VA72C10
VA72C10
VA72C10's Avatar
Shocks:
Front- Monroe 33033
Rear- Monroe 32301
I looked these up on google and a place called rockauto sells them on evilbay for 18.99 plus shipping. The question I have is they show an application on the rear as stock for a 69 chevy pickup. Are we using a stock shock because of the relocators and blocks?
Old 02-03-2009, 10:07 PM   #14
lolife99
lolife99's Avatar
If that's correct they are too long.
Keith
Old 02-04-2009, 09:50 AM   #15
au03z71
au03z71's Avatar
BUMP. This would be good to know
Old 02-04-2009, 06:45 PM   #16
gringoloco
A guy with a truck
gringoloco's Avatar
The 33033s are listed as stock replacements as well, but they are definitely short enough. I dunno?
We just installed the 32301s on a buddy's '65 C10 with RE7s, relocators, and 2" blocks. Worked perfectly. I have a set on the shelf awaiting install on my '70 C10, similarly equipped. My measurements say they will work.
There should be just over 12" between the relocator's mounting eyes out back when aired-out. The 32301s are 11.875" compressed.
Best bet is to measure for your individual needs. Very rarely do I trust the internet without verifying for myself- been burned a few times on that deal- trucks and individual results may vary...
-Chris
Old 02-05-2009, 10:02 AM   #17
lolife99
lolife99's Avatar
Here's a good list of front and rear shocks off of CPP's website.
File Type: txt front shocks.txt (933 Bytes, 559 views)
File Type: txt KYB shock list.txt (614 Bytes, 231 views)
Keith
Old 02-05-2009, 10:54 AM   #18
VA72C10
VA72C10
VA72C10's Avatar
Thanks for the info!
Old 02-05-2009, 08:36 PM   #19
lolife99
lolife99's Avatar
The KYB's that ECE sells for their 6" rear drop are part # 344067. I saved the end off of the box.
Does anyone have the actual part number for the dropped KYB's that ECE uses up front?
CPP lists them as #KYM1200G off of the above list I posted. I need the real part number.
Keith
Old 02-05-2009, 11:04 PM   #20
68 short step
good info here...
68 short step is offline   Reply With Quote
Old 02-08-2009, 01:46 PM   #21
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Bump for a possible answer...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
